Ahead of its time, ahead of the game is the Gigabyte GeForce RTX 4060 Ti AERO 8G Graphics Cards. Powered by NVIDIA's RTX architecture, the GIGABYTE GeForce RTX 4060 Ti AERO 8G brings stunning visuals, amazingly fast frame rates, and AI acceleration to games and creative applications with its enhanced RT Cores and Tensor Cores, along with a staggering 8 GB of GDDR6 memory.
WindForce cooling system
The WINDFORCE cooling system features three 80 mm unique blade fans, alternate spinning, 4 composite copper heat pipes directly touch the GPU, 3D active fans and Screen cooling, which together provide high efficiency heat dissipation. -
RGB Fusion
With 16.7M customizable color options and numerous lighting effects, you can choose any lighting effect or synchronize with other devices in Gigabyte control center. -
Protection metal back plate
The metal back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection. -
Dual BIOS
The factory default setting is OC mode, which provides users with the best performance. However, switching to silent mode will enjoy a quieter experience. -
Power indicator
When experiencing any power supply abnormality, the indicator will alert gamers by flashing light. -
Ultra Durable
Ultra Durable certified highest-grade metal chokes, lower ESR solid capacitors, 2 oz copper PCB, and lower RDS (on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life. -
Friendly PCB design
Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
- Gigabyte GeForce RTX 4060 Ti AERO OC 8G - graphics card - GeForce RTX 4060 Ti - 8 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4060 Ti - up to
- Memory
- 8 GB GDDR6
- Memory Speed
- 18 Gbps
- Core Clock
- 2580 MHz
- CUDA Cores
- 4352
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DisplayPort , 2 x HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 5 cm x 28.1 cm x 11.7 cm
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2580 MHz
- CUDA Cores
- 4352
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Dual Bios, GIGABYTE WINDFORCE cooling design, metal backplate, NVIDIA Ada Lovelace GPU technology, 3D Active Fan, Gigabyte Alternate Spinning, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, Heat Pipe Direct Touch technology, screen cooling, Graphene Nano Lubricant, RGB fusion
- Size
- 8 GB
- Technology
- GDDR6 SDRAM
- Memory Speed
- 18 Gbps
- Bus Width
- 128-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- Gigabyte Control Center
- DisplayPort 1.4a
- 5 cm
- 28.1 cm
- 11.7 cm
