Gigabyte GeForce RTX 4060 AERO OC 8G Graphics Card
Quicklinx: HVH5WS00 Mfr#: GV-N4060AERO OC-8GD
  • Powered by NVIDIA DLSS 3, ultra-efficient Ada Lovelace arch, and full ray tracing
  • 4th Generation Tensor Cores: Up to 4x performance with DLSS 3 vs. brute-force rendering
  • 3rd Generation RT Cores: Up to 2X ray tracing performance
  • Powered by GeForce RTX™ 4060
  • Integrated with 8GB GDDR6 128bit memory interface
  • WINDFORCE Cooling System
  • RGB Fusion
  • Dual BIOS
  • Protection metal back plate
  • Windforce cooling system
    The Windforce cooling system features three 80 mm unique blade fans, alternate spinning, composite copper heat pipes that directly touch the GPU, 3D active fans and Screen cooling, which together provide high efficiency heat dissipation.
  • RGB fusion
    With 16.7M customizable color options and numerous lighting effects, you can choose any lighting effect or synchronize with other devices in GIGABYTE control center.
    The metal back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection.
  • Dual BIOS
    The factory default setting is OC mode, which provides users with the good performance. However, switching to silent mode will enjoy a quieter experience.
  • Power indicator
    When experiencing any power supply abnormality, the indicator will alert gamers by flashing light.
  • Ultra cooling
    Lower RDS(on) MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging at extremely low temperature.
  • Low power loss
    Metal Choke hold energy much longer than common iron-core chokes at high frequency, thus effectively reduce core energy loss and EMI interference.
  • Longer life
    Lower ESR Solid Capacitors ensure better electronic conductivity for excellent system performance and longer lifespan.
  • Friendly PCB design
    Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
  • Power through the game
    GIGABYTE offers good power supply solutions for your graphics cards. You can choose either the Aorus series or the UD series to power your graphics card.
  • GIGABYTE control center
    GIGABYTE control center is a unified software for all GIGABYTE supported products. It provides an intuitive interface that allows users to adjust clock speed, voltage, fan mode and power target in real-time.
Gigabyte GeForce RTX 4060 AERO OC 8G - graphics card - GeForce RTX 4060 - 8 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4060 - up to
8 GB GDDR6
Memory Speed
17 Gbps
Core Clock
2550 MHz
CUDA Cores
3072
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x DisplayPort (version 1.4a) , 2 x HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
3.8 cm x 28.1 cm x 11.4 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2550 MHz
CUDA Cores
3072
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3D Active Fan, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, composite copper heat pipes, Dual Bios, Gigabyte Alternate Spinning, GIGABYTE WINDFORCE cooling design, Graphene Nano Lubricant, Heat Pipe Direct Touch technology, LED indicator, metal backplate, NVIDIA Ada Lovelace GPU technology, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, RGB fusion, screen cooling, Triple Fan Design
Size
8 GB
GDDR6 SDRAM
Memory Speed
17 Gbps
Bus Width
128-bit
Required Power Supply
450 W
Additional Requirements
8 pin PCI Express power connector
Software Included
Gigabyte Control Center
3.8 cm
28.1 cm
11.4 cm
