GIGABYTE GeForce RTX 4060 AERO OC 16GB Graphics Card
Quicklinx: HX0TWS00 Mfr#: GV-N406TAERO OC-16GD
Combined with the latest generation of the GeForce RTX 40 series and the WINDFORCE cooling system, the GIGABYTE GeForce RTX 4060 Ti AERO OC 16G provides the high-efficiency of heat dissipation while unleashing the best performance of the GPU and delivering the ultimate experience for both gaming and creating.
  • WINDFORCE cooling system
    The WINDFORCE cooling system features three 80 mm unique blade fans, alternate spinning, 4 composite copper heat pipes directly touch the GPU, 3D active fans and screen cooling, which together provide high efficiency heat dissipation.
  • Alternate spinning
    Reduce the turbulence of adjacent fans and increase airflow pressure.
  • 3D Active Fan
    The 3D Active Fan provides semi-passive cooling, and the fans will remain off when the GPU is in a low load or low power game.
  • Unique blade fan
    The airflow is split by the triangular fan edge, and guided smoothly through the 3D stripe curve on the fan surface.
  • Graphene nano lubricant
    Graphene nano lubricant can extend the life of fan by 2.1 times, close to the life of double ball bearing, and is quieter.
  • Screen cooling
    Extended heatsink design allows air flow to pass through, providing better heat dissipation.
  • Heat pipes direct touch
    The shape of the pure copper heat pipe maximizes the direct contact area with the GPU. The heat pipe also covers the VRAM through a metal plate contact to ensure proper cooling
  • RGB fusion
    With 16.7M customizable color options and numerous lighting effects, you can choose any lighting effect or synchronize with other devices in GIGABYTE control center.
  • Protection metal back plate
    The metal back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection.
  • Dual BIOS
    The factory default setting is OC mode, which provides users with good performance. However, switching to silent mode will enjoy a quieter experience.
  • Power indicator
    When experiencing any power supply abnormality, the indicator will alert gamers by flashing light.
  • Ultra durable
    Ultra durable certified high-grade metal chokes, lower ESR solid capacitors, 2oz copper PCB, and lower RDS(on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life.
  • Friendly PCB design
    Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
  • Power through the game
    GIGABYTE offers the strong power supply solutions for your graphics cards. You can choose either the AORUS series or the UD series to power your graphics card.
Gigabyte GeForce RTX 4060 Ti AERO OC 16G - graphics card - GeForce RTX 4060 Ti - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4060 Ti - up to
16 GB GDDR6
Memory Speed
18 Gbps
Core Clock
2595 MHz
CUDA Cores
4352
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x DisplayPort (version 1.4a) , 2 x HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
5 cm x 28.1 cm x 11.7 cm
3-year warranty
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2595 MHz
CUDA Cores
4352
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3D Active Fan, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, composite copper heat pipes, Dual Bios, Gigabyte Alternate Spinning, GIGABYTE WINDFORCE cooling design, Graphene Nano Lubricant, Heat Pipe Direct Touch technology, metal backplate, NVIDIA Ada Lovelace GPU technology, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, RGB fusion, screen cooling
Size
16 GB
GDDR6 SDRAM
Memory Speed
18 Gbps
Bus Width
128-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
Software Included
Gigabyte Control Center
5 cm
28.1 cm
11.7 cm
Limited warranty - 3 years
