Gigabyte GeForce GTX TITAN 6GB PCI-Express 3.0 HDMI
Quicklinx: 8JZXWS00 Mfr#: GV-NTITAN-6GD-B
  • NVIDIA GeForce GTX TITAN
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Introducing the world's first gaming supercomputer--GeForce® GTX TITAN.
Now, you can get the same technology that powers the world's fastest supercomputer--Oak Ridge National Laboratory's Titan--in your gaming PC. GeForce GTX TITAN takes advantage of the NVIDIA® Kepler™ architecture to give you unprecedented levels of power, performance, and control, delivered with stunning craftsmanship. This means you can play the most graphics-intensive games at max settings and the highest frame rates--every title, every time.
GTX TITAN is supercomputing reimagined for PC gaming.
Each Gigabyte GV-NTITAN-6GD-B Includes a MP8000 Gaming Mouse Pad FREE
With the DNA of the world's fastest supercomputer and the soul of NVIDIA® Kepler™, GeForce® GTX TITAN is a revolution in PC gaming. GeForce GTX TITAN introduces a new class of gaming PCs: the gaming supercomputer. It delivers the superior combination of power, performance, efficiency, control, and acoustics that PC gamers demand in their favorite--and most challenging--titles.
The Gaming Supercomputer
Using the same Kepler architecture-based GPUs that power the world's fastest supercomputer, TITAN delivers extreme power and efficiency to the home gaming PC.
  • Extraordinary power and efficiency
  • 3-way NVIDIA SLI® technology for the most extreme PC gaming play
Precision Control
Get awesome power with absolute control to extract maximum performance.
  • Pushes the PC to the maximum with precise controls using NVIDIA GPU Boost 2.0
  • Provides users with advanced controls like GPU temperature target, overclocking, and overvoltage
Redefining the Gaming Experience
Offers a superior combination of power, performance, efficiency, control, and acoustics that PC gamers need for premium PC gaming
  • Up to 4K resolution or multiple monitors
  • Premium features like NVIDIA TXAA™, NVIDIA PhysX®, and NVIDIA 3D Vision®
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA Surround™
  • Support for four concurrent displays including:
  • Two dual-link DVI
  • HDMI1
  • DisplayPort 1.2
  • Microsoft DirectX 11.1 API (feature level 11_0)
  • NVIDIA 3D Vision-Ready2
  • NVIDIA SLI-Ready
  • NVIDIA CUDA® technology
  • PCI Express 3.0 support
  • OpenGL 4.3 support
  • OpenCL™ support
A beauty--and a beast
  • Combined beauty and power
  • Beauty: GTX TITAN delivers refined design and capability to power smaller, elegant PC machines without sacrificing performance and efficiency
  • Beast: GTX TITAN redefines the gaming experience with the power of supercomputer DNA with 3-way NVIDIA SLI®
Specifcations
  • GPU GeForce GTX TITAN
  • Core Base Clock 837 MHz
  • Core Boost Clock 876 MHz
  • Memory Clock 6008 MHz
  • Memory Size 6144MB GDDR5
  • Bus Type PCI Express 3.0
  • Memory Bus 384-bit
  • CUDA Cores 2688
  • Memory type 64Mx32
  • DirectX 11.1 Yes
  • DVI Port DVI-I /DVI-D
  • DisplayPort Yes
  • HDCP Yes
  • HDMI Yes
  • Accessory AIVIA MP8000 Mouse PAD, HDMI Cable, DVI to D-Sub adapter, Driver DVD(OC GURU II),6pin+8pin cable, QSG, AIVIA poke card
  • Game spirits unlocked
    Bring supercomputing power to your PC with the fast single-GPU graphics card. Take it to the extreme with 3-way NVIDIA SLI technology, NVIDIA TXAA, NVIDIA PhysX and NVIDIA 3D VISION to drive the most extreme gaming PCs on the planet.
  • NVIDIA GPU Boost 2.0 technology
    Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers some levels of customization, including GPU temperature target, overclocking, and unlocked voltage.
Gigabyte GV-NTITAN-6GD-B - graphics card - GF GTX TITAN - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
6 GB GDDR5
Core Clock
837 MHz
Boost Clock
876 MHz
Effective Memory Clock
6.008 GHz
Memory Interface
384-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 11.1, OpenGL 4.3
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
837 MHz
Boost Clock
876 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Nvidia 3-way SLI ready, Nvidia PhysX-Ready, Nvidia 3D Vision technology, TXAA, NVIDIA Adaptive Vertical Sync, OC Guru II, NVIDIA GPU Boost 2.0
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
384-bit
Required Power Supply
600 W
Software Included
Drivers & Utilities, OC Guru ll
