The WINDFORCE 3X cooling system features four 6 mm and two 8 mm composite heat-pipes, special fin architecture, unique blade fan design and GIGABYTE "Triangle Cool" technology, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
The middle fan spins in the reverse direction to optimize air flow to dissipate heat more effectively for accomplishing higher performance at a lower temperature.
The fans will remain off when the GPU is under a set loading or temperature for low power gaming. The LED fan indicator on the top of the graphics card provides an instant display of the fan status.
The WINDFORCE 3X cooling system features four 6 mm and two 8 mm composite heat-pipes, special fin architecture, unique blade fan design and GIGABYTE "Triangle Cool" technology, together delivering an effective heat dissipation capacity for higher performance at lower temperatures. -
Alternate spinning fan design
The middle fan spins in the reverse direction to optimize air flow to dissipate heat more effectively for accomplishing higher performance at a lower temperature. -
3D active fan with LED indicators
The fans will remain off when the GPU is under a set loading or temperature for low power gaming. The LED fan indicator on the top of the graphics card provides an instant display of the fan status. -
Unique blade fan design
The airflow is spilled through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhances the cooling capacity while reducing air turbulence. -
GPU Gauntlet sorting
Forged with only the top-notch GPU, the Gigabyte XTREME GAMING graphics cards guarantee the higher overclocking capability in terms of excellent power switching, ensuring the highest performance without compromising system reliability. -
LED power indicators to show if the PCI-E voltage from PSU is stable
Be alert when PCI-E voltage is unstable with the smart power LED indicators. When experiencing any power abnormality, the indicator will alert gamers by flashing light. Abnormal power-related events will recorded in the system as well through OC GURU utility software as a useful reference for troubleshooting. -
Aerospace-grade PCB coating for best protection
PCB applied with a breathable aerospace-grade coating to shield against moisture, dust, and corrosion for a complete protection.
- Gigabyte GV-N98TXTREME-6GD - graphics card - GF GTX 980 Ti - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 980 Ti
- Memory
- 6 GB GDDR5
- Core Clock
- 1216 MHz
- Boost Clock
- 1317 MHz
- Effective Memory Clock
- 7200 MHz
- Memory Interface
- 384-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1216 MHz
- Boost Clock
- 1317 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable VGA, GIGABYTE GPU Gauntlet Sorting, GIGABYTE WindForce 3x, Triangle Cool Technology, OC Guru II, 12+2 Phase Power Design
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7200 MHz
- Bus Width
- 384-bit
- Required Power Supply
- 600 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- Software Included
- OC Guru ll
