Gigabyte GeForce GTX 980Ti 6GB GDDR5 PCIe3.0 WINDFORCE Graphics Card
Quicklinx: BY51WS00 Mfr#: GV-N98TWF3-6GD
  • NVIDIA GeForce GTX 980 Ti
The graphics card features WINDFORCE 3X cooling system that is equipped with high performance pure copper heat-pipes which are attached to the GPU and can strengthen the speed of heat dissipation. Besides, the air flow is effectively enhanced by the unique blade fan design, thus not only increasing the cooling capacity while reducing air turbulence but also resulting in a lower noise level. The product is also equipped with pure copper heat pipe direct touch (HDT) technology, delivering superior cooling capacity and heat transfer efficiency at an extremely low noise level.
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in Ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
  • WINDFORCE 3X cooling system
  • Heat pipe direct touch
    The product is equipped with pure copper heat pipe direct touch (HDT) technology, delivering superior cooling capacity and heat transfer efficiency at an extremely low noise level.
  • Flex display technology
  • Lower GPU temperature
    Ultra-durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB.
  • Better overclocking capability
    Ultra-durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability.
  • Decrease power switching loss
    Ultra-durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
  • OC GURU II
    The intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
Gigabyte GV-N98TWF3-6GD - graphics card - GF GTX 980 Ti - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
6 GB GDDR5
Core Clock
1000 MHz
Boost Clock
1075 MHz
Effective Memory Clock
7.01 GHz
Memory Interface
384-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , 3 x DisplayPort , HDMI , DVI-D (dual link)
API Supported
OpenGL 4.4, DirectX 12
3.6 cm x 27.9 cm x 11.6 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1000 MHz
Boost Clock
1075 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Ultra Durable VGA, GIGABYTE WindForce 3x, GPU Boost technology, GIGABYTE Flex Display Technology, Heat Pipe Direct Touch technology
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
384-bit
Required Power Supply
600 W
Additional Requirements
2 x 8 pin PCI Express power connector
Software Included
OC Guru ll
3.6 cm
27.9 cm
11.6 cm
