The graphics card features WINDFORCE 3X cooling system that is equipped with high performance pure copper heat-pipes which are attached to the GPU and can strengthen the speed of heat dissipation. Besides, the air flow is effectively enhanced by the unique blade fan design, thus not only increasing the cooling capacity while reducing air turbulence but also resulting in a lower noise level. The product is also equipped with pure copper heat pipe direct touch (HDT) technology, delivering superior cooling capacity and heat transfer efficiency at an extremely low noise level.
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in Ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
WINDFORCE 3X cooling system that is equipped with high performance pure copper heat-pipes which are attached to the GPU and can strengthen the speed of heat dissipation. Besides, the air flow is effectively enhanced by the unique blade fan design, thus not only increasing the cooling capacity while reducing air turbulence but also resulting in a lower noise level. -
Heat pipe direct touch
The product is equipped with pure copper heat pipe direct touch (HDT) technology, delivering superior cooling capacity and heat transfer efficiency at an extremely low noise level. -
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in Ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy. -
Lower GPU temperature
Ultra-durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. -
Better overclocking capability
Ultra-durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. -
Decrease power switching loss
Ultra-durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. -
OC GURU II
The intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
- Gigabyte GV-N98TWF3-6GD - graphics card - GF GTX 980 Ti - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 980 Ti
- Memory
- 6 GB GDDR5
- Core Clock
- 1000 MHz
- Boost Clock
- 1075 MHz
- Effective Memory Clock
- 7.01 GHz
- Memory Interface
- 384-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , 3 x DisplayPort , HDMI , DVI-D (dual link)
- API Supported
- OpenGL 4.4, DirectX 12
- 3.6 cm x 27.9 cm x 11.6 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1000 MHz
- Boost Clock
- 1075 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable VGA, GIGABYTE WindForce 3x, GPU Boost technology, GIGABYTE Flex Display Technology, Heat Pipe Direct Touch technology
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.01 GHz
- Bus Width
- 384-bit
- Required Power Supply
- 600 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- Software Included
- OC Guru ll
- 3.6 cm
- 27.9 cm
- 11.6 cm
