Gigabyte GeForce GTX 960 OC 4GB GDDR5 Dual Link DVI HDMI PCI-E
Quicklinx: B4ZRWS00 Mfr#: GV-N960WF2OC-4GD
  • NVIDIA GeForce GTX 960
The airflow is spilt through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
When the GPU is under a set loading or temperature, the fans will remain off, creating an absolutely silent environment for gamers.
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. It reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability.
  • Windforce 2X with unique blade fan
    Equipped with two 90mm unique blade fan and three copper heat pipes. The airflow is spilt through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
  • 0dB semi-passive fans
    Featuring the semi-passive fan design. When the GPU is under a set loading or temperature, the fans will remain off, creating an absolutely silent environment for gamers.
  • Flex Display technology
  • Lower GPU Temperature
  • Better overclocking capability
    Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability.
  • Decrease power switching loss
    Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
Gigabyte GV-N960WF2OC-4GD - graphics card - GF GTX 960 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1241 MHz
Boost Clock
1304 MHz
Effective Memory Clock
7.01 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , 3 x DisplayPort , HDMI , DVI-D (dual link)
API Supported
OpenGL 4.4, DirectX 12
4.3 cm x 25.7 cm x 11.4 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1241 MHz
Boost Clock
1304 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Ultra Durable VGA, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 2x, Dual Fan Design, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, GIGABYTE Flex Display Technology, 0dB semi-passive fans
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
128-bit
Required Power Supply
400 W
Additional Requirements
6-pin + 8-pin power connectors
4.3 cm
25.7 cm
11.4 cm
