Gigabyte GeForce GTX 960 2GB PCI-Express 3.0 OC ITX
Quicklinx: B1VCWS00 Mfr#: GV-N960IXOC-2GD
  • NVIDIA GeForce GTX 960
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Powered by NVIDIA GeForce GTX 960 GPU
Integrated with industry's best 2GB GDDR5 memory 128-bit memory interface
BASE: 1165 MHz / BOOST: 1228 MHz(1190/1253 MHz in OC Mode)
Features Dual-link DVI-I / Dual-link DVI-D / HDMI / DisplayPort
System power supply requirement: 400W (with one 6-pin external power connectors)
Ideal Cooling - 90mm Large Fansink
- Packed with GIGABYTE's unique blade fan design and pure copper heat pipe direct touch (HDT) technology, delivering superior cooling capacity and heat transfer efficiency at an extremely low noise level.
- Optimized fan speed according to real-time GPU temperature, effectively improving power efficiency.
- Measuring merely 17cm in length, the card, perfectly compatible for building most of the PCs from ATX to mini-ITX.
Ideal Durability - UDV
- Better overclocking performance by reducing voltage ripples in normal and transient state
- Lower temperature by doubling the copper inner layer of PCB and improving heat transfer efficiency
- Less power loss by stabilizing the electric current and reducing electrical impedance
OC GURU ll
Brand-new intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
  • GIGABYTE custom-designed 90mm cooler
    Packed with GIGABYTE's unique blade fan design and pure copper heat pipe direct touch (HDT) technology, delivering superior cooling capacity and heat transfer efficiency at an extremely low noise level. Optimized fan speed according to real-time GPU temperature, effectively improving power efficiency. Measuring merely 17cm in length, the card, perfectly compatible for building most of the PCs from ATX to mini-ITX.
  • OC GURU II
    Intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
  • Lower GPU temperature
    Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB.
  • Better overclocking capability
    Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability.
  • Decrease power switching loss
    Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
Gigabyte GV-N960IXOC-2GD - graphics card - GF GTX 960 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 960 - up to
2 GB GDDR5
Core Clock
1165 MHz
Boost Clock
1228 MHz
Effective Memory Clock
7.01 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , DisplayPort , HDMI , DVI-D (dual link)
API Supported
OpenGL 4.4, DirectX 12
4.2 cm x 18.1 cm x 13.6 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1165 MHz
Boost Clock
1228 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Ultra Durable VGA, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, GIGABYTE custom-designed 90 mm cooler
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
128-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
Software Included
OC Guru ll
4.2 cm
18.1 cm
13.6 cm
