PLAY THE FUTURE - GeForce® GTX™ 950
The GeForce GTX 950 is a true gaming GPU designed for every PC gamer. It’s built to the exacting specifications of the GeForce GTX family and powered by NVIDIA Maxwell™—the most advanced GPU architecture ever created—to deliver 3x the performance of previous-generation cards.
The GeForce GTX 950 transforms your PC into a gaming rig to rival any game console. Enjoy fast and responsive MOBA gaming and the latest games in 1080p. Plus, it delivers a more interactive and cinematic experience with advanced visual effects driven by NVIDIA GameWorks™ and advanced DirectX 12.
FULL HD PERFORMANCE
Maxwell’s exceptional performance and efficiency means you can transform your basic PC into a modern gaming rig that can play the latest games at 1080p.
STEP ABOVE A CONSOLE
More powerful than any console, this card delivers a truly interactive, cinematic experience in the latest games with advanced effects driven by NVIDIA GameWorks™ and DirectX™ 12.
GET THE EDGE FOR MOBA
Competitive gamers demand instant responsiveness and low latency. The GeForce GTX 950 is designed from the ground up for the MOBA gamer, giving you the power and performance to rule the game.
NEW WAYS TO PLAY
GeForce Experience™ makes it easy to share your gameplay or co-play online with friends. With GeForce GTX, stream PC games to your NVIDIA® SHIELD™ devices using NVIDIA GameStream™.
Ready to get real about gaming? Experience the performance of the new GeForce GTX 950.
• Powered by NVIDIA GeForce GTX 950 GPU
• Integrated with industry's best 2GB GDDR5 memory and 128-bit memory interface
• OC Edition - Core Clock: Base 1064MHz / Boost 1241MHz (Standard- Base:1026MHz Boost:1190MHz)
• Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort
• System power supply requirement: 350W (with one 6-pin external power connector)
GIGABYTE custom-designed 90mm cooler
GIGABYTE custom-designed 90 mm cooler, with air flow optimized cover and aluminum base. The cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise.
Unique Blade Fan Design
The airflow is spilt through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
Optimized Card Size
Measuring merely 17cm in length, the card, perfectly compatible for building most of the PCs from ATX to mini-ITX.
OC GURU ll
Brand-new intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
GeForce GTX 950
Core Clock: Base/Boost clock: 1064 / 1241 MHz (standard:1026/1190)
Memory Clock: 6610 MHz
Process Technology: 28 nm
Memory Size: 2 GB
Memory Bus: 128 bit
Card Bus: PCI-E 3.0
Memory Type: GDDR5
DirectX 12
OpenGL 4.5
PCB Form: ATX
Digital max resolution 4096 X 2160
Analog max resolution 2048 x 1536
I/O: Dual-link DVI-Ix1/DVI-Dx1/HDMIx1/Display Portx1
Card size: H=42 mm, L=186 mm, W=136 mm
Power requirement 350W (with one 6-pin external power connector)
