Gigabyte GeForce GTX 770 1137MHz 2GB PCI-E 3.0 HDMI Windforce 3X
Quicklinx: 8QNHWS00 Mfr#: GV-N770OC-2GD
  • NVIDIA GeForce GTX 770
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
  • NEW WINDFORCE 3X 2 Slot 450W fan sink with "Triangle Cool"
  • Core/Mem clock: 1137 MHz (std 1046MHz)
  • Boost Clock: 1189 MHz (std 1085MHz)
  • 8-Phase power benefits with GPU Boost 2.0
  • OC GURU II with GPU Boost 2.0 Technology
Specifcations
  • Model name GV-N770OC-2GD
  • GPU GTX 770
  • Core Clock (MHz) Base: 1137MHz (std 1046 MHz) Boost: 1189 MHz (std 1085 MHz)
  • Stream Processor 1536
  • Mem Clock (MHz) 7000MHz
  • Mem Size 2048MB
  • Mem Bus (bit) 256 bit
  • Mem Type 64Mx32 GDDR5
  • Memory (pcs) 8
  • I/O Dual link DVI-I / DV-D HDMI x1 Displayport
  • DirectX OpenGL DirectX 11.1 OpenGL 4.3
  • Card Interface PCI Express 3.0
  • Board Form ATX 2 slot
  • Fan/Heat Sink WIINDFORCE 3X 2 slot 450W with "Triangle Cool"
  • Card Size H=38mm L=287mm W=130m
  • WindForce 3X 2-slot 450 W cooling system
    Keeping the same 450 W cooling capacity using 2 slots, the WindForce 3X 450 W cooling system is equipped with two 8 mm and four 6 mm cooper heat-pipes, inclined fans, and Gigabyte "Triangle Cool" technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
  • OC GURU II
    OC GURU II is an instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, GPU voltage, memory voltage, OSD, online support and update driver, BIOS directly.
  • Up to 4 displays on a single card
    In the Kepler architecture, support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Gigabyte GV-N770OC-2GD - graphics card - GF GTX 770 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 770 - up to
2 GB GDDR5
Core Clock
1137 MHz
Boost Clock
1189 MHz
Effective Memory Clock
7.01 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
4
Interfaces Details
DisplayPort , HDMI , DVI-I (dual link) , DVI-D
API Supported
DirectX 11.1, OpenGL 4.3
4.3 cm x 29.2 cm x 12.9 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1137 MHz
Boost Clock
1189 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
4
Interfaces Details
API Supported
Dual Slot Fan Cooler, Ultra Durable VGA, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 3x, Nvidia SLI ready, Triangle Cool Technology, NVIDIA Adaptive Vertical Sync, Kepler GPU Architecture, OC Guru II, NVIDIA GPU Boost 2.0
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
256-bit
Required Power Supply
600 W
4.3 cm
29.2 cm
12.9 cm
