Powered by NVIDIA GeForce GTX 750 Ti GPU
Integrated with the first 2048MB GDDR5 memory and 128-bit memory interface
Core Clock: Base 1020MHz / Boost 1085MHz
Features Dual-link DVI-I / DVI-D / HDMIx2
Support PCI Express 3.0 x16 bus interface
System power supply requirement: 400W
GIGABYTE custom-designed 10 cm cooler
As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower.
Up to 4 displays on a Single Card
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Gold Plated HDMI x 2
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card.
Ultra Durable 2
Ultra Cooling - Low RDS(on) MOSFET Design
Low Power Loss - Ferrite Core Choke Design
Longer Life - All-Solid Capacitor Design
OC GURU ll
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Gigabyte custom-designed 10 cm cooler
As opposed to the stereotype, Gigabyte is able to maximize fan size to 10cm with its cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower. -
Up to 4 displays on a single card
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience. -
Gold plated HDMI x 2
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card.
- Gigabyte GV-N75TD5-2GI - graphics card - GF GTX 750 Ti - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti - up to
- Memory
- 2 GB GDDR5
- Core Clock
- 1020 MHz
- Boost Clock
- 1085 MHz
- Effective Memory Clock
- 5.4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
- API Supported
- OpenGL 4.4, DirectX 12
- 4.3 cm x 18.4 cm x 13.6 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1020 MHz
- Boost Clock
- 1085 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Nvidia GeForce 3D Vision Ready, Nvidia PhysX-Ready, Ultra Durable 2, solid state capacitors, GIGABYTE custom-designed 100 mm cooler, Gold plated HDMI, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, OC Guru II
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 400 W
- Software Included
- OC Guru ll
- 4.3 cm
- 18.4 cm
- 13.6 cm
