Gigabyte GeForce GTX 750Ti 2GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: BKLDWS00 Mfr#: GV-N75TD5-2GI
  • NVIDIA GeForce GTX 750 Ti
Powered by NVIDIA GeForce GTX 750 Ti GPU
Integrated with the first 2048MB GDDR5 memory and 128-bit memory interface
Core Clock: Base 1020MHz / Boost 1085MHz
Features Dual-link DVI-I / DVI-D / HDMIx2
Support PCI Express 3.0 x16 bus interface
System power supply requirement: 400W
GIGABYTE custom-designed 10 cm cooler
As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower.
Up to 4 displays on a Single Card
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Gold Plated HDMI x 2
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card.
Ultra Durable 2
Ultra Cooling - Low RDS(on) MOSFET Design
Low Power Loss - Ferrite Core Choke Design
Longer Life - All-Solid Capacitor Design
OC GURU ll
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
  • Gigabyte custom-designed 10 cm cooler
    As opposed to the stereotype, Gigabyte is able to maximize fan size to 10cm with its cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower.
  • Up to 4 displays on a single card
  • Gold plated HDMI x 2
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card.
Gigabyte GV-N75TD5-2GI - graphics card - GF GTX 750 Ti - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750 Ti - up to
2 GB GDDR5
Core Clock
1020 MHz
Boost Clock
1085 MHz
Effective Memory Clock
5.4 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
API Supported
OpenGL 4.4, DirectX 12
4.3 cm x 18.4 cm x 13.6 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1020 MHz
Boost Clock
1085 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Nvidia GeForce 3D Vision Ready, Nvidia PhysX-Ready, Ultra Durable 2, solid state capacitors, GIGABYTE custom-designed 100 mm cooler, Gold plated HDMI, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, OC Guru II
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
Required Power Supply
400 W
Software Included
OC Guru ll
4.3 cm
18.4 cm
13.6 cm
