Gigabyte GeForce GTX 750 Ti OC 1GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: BKR1WS00 Mfr#: GV-N75TOC-1GI
  • NVIDIA GeForce GTX 750 Ti
As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower. The airflow is split through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
  • Unique blade fan design
  • Up to 4 displays on a single card
    Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
  • Gold plated HDMI x 2
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card.
  • Ultra cooling
    Lower RDS(on) MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging at extremely low temperature.
  • Low power loss
    Ferrite core chokes hold energy much longer than common iron-core chokes at high frequency, thus effectively reduce core energy loss and EMI interference.
  • Longer life
    Lower ESR solid capacitors ensure better electronic conductivity for excellent system performance and longer lifespan.
  • OC GURU 2
    Brand-new intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
Gigabyte GV-N75TOC-1GI (rev. 1.0) - OC Edition - graphics card - GF GTX 750 Ti - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
1 GB GDDR5
Core Clock
1033 MHz
Boost Clock
1111 MHz
Effective Memory Clock
5.4 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
API Supported
OpenGL 4.4, DirectX 12
4.3 cm x 18.5 cm x 13.5 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1033 MHz
Boost Clock
1111 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Ultra Durable 2, Gold plated HDMI, OC Guru II
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
Software Included
OC Guru ll
4.3 cm
18.5 cm
13.5 cm
