Gigabyte GeForce GTX 750 Ti 1163MHz 2GB PCI-E 3.0 WF2X
Quicklinx: 9NXHWS00 Mfr#: GV-N75TWF2BK-2GI
  • NVIDIA GeForce GTX 750 Ti
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Gigabyte Black Edition Graphics Cards undergo an extra 168 hours (7 days) of stress testing before shipment to ensure premium quality for the customers.
During the 168 hour test, each graphics card needs to pass rigorous, full system validation testing for 1 full week. Gigabyte has built a custom testing facility at Taiwan (Nanping) factory.
  • WindForce 2X Anti-turbulence-Parallel inclined fan
    WINDFORCE 2X parallel-inclined fin design is equipped with 2 ultra quiet PWM fans and copper heat pipe to enlarge air channel on the graphics card vents and creates a more effective airflow system in chassis.
  • Gold plated HDMI
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
  • Up to 4 displays on a single card
    Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
  • OC GURU ll
    Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
Gigabyte GV-N75TWF2BK-2GI - Black Edition - graphics card - GF GTX 750 Ti - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750 Ti - up to
2 GB GDDR5
Core Clock
1163 MHz
Boost Clock
1242 MHz
Effective Memory Clock
5.4 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
API Supported
DirectX 11.2, OpenGL 4.4
4.2 cm x 20.4 cm x 14.4 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1163 MHz
Boost Clock
1242 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 2x, Dual Fan Design, Gold plated HDMI, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, OC Guru II
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
Required Power Supply
400 W
Software Included
OC Guru ll
4.2 cm
20.4 cm
14.4 cm
