Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. -
Up to 4 displays on a single card
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience. -
OC Guru ll
- Gigabyte GV-N75TOC-2GL - graphics card - GF GTX 750 Ti - 2 GB
- Graphics card - low profile
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti - up to
- Memory
- 2 GB GDDR5
- Core Clock
- 1033 MHz
- Boost Clock
- 1111 MHz
- Effective Memory Clock
- 5.4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , DisplayPort , 2 x HDMI
- API Supported
- DirectX 11.2, OpenGL 4.4
- 4.2 cm x 17.5 cm x 12.1 cm
- Bus Type
- Graphics Engine
- Core Clock
- 1033 MHz
- Boost Clock
- 1111 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Nvidia PhysX-Ready, Ultra Durable 2, Nvidia 3D Vision technology, Gold plated HDMI, Adaptive V-Sync, NVIDIA GPU Boost, OC Guru II
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 400 W
- Included Accessories
- Low-profile bracket
- Software Included
- OC Guru ll
- 4.2 cm
- 17.5 cm
- 12.1 cm
