Gigabyte GeForce GTX 750 1GB PCI-E 3.0 HDMI OC
Quicklinx: 98FBWS00 Mfr#: GV-N750OC-1GI
  • High-Definition Multimedia Interface (HDMI)
GV-N750OC-1GI
  • Ultra Durable 2 Series
  • Powered by NVIDIA GeForce GTX 750 GPU
  • Integrated with the first 1024MB GDDR5 memory and 128-bit memory interface
  • OC Edition : Base 1059MHz/Boost 1137MHz
  • Features Dual-link DVI-I / DVI-D / HDMI*2
  • Support PCI Express 3.0 x16 bus interface
  • System power supply requirement: 400W
  • Chipset GeForce GTX 750
  • Memory Clock 5000 MHz
  • Process Technology 28 nm
  • Memory Size 1024MB GDDR5
  • Memory Bus 128-bit
  • Core Clock Base:1059MHz/Boost:1137MHz (Standard- Base:1020MHz Boost:1085MHz)
  • Card Bus PCI Express 3.0
  • DirectX 11.2
  • OpenGL 4.4
  • PCB Form ATX
  • Digital max resolution 4096 X 2160 (via 2 HDMI)
  • Analog max resolution 2048 x 1536
  • Multi-view 4
  • I/O Dual-link DVI-I1/DVI-D1/HDMI*2
  • Card size L=185mm, W=135mm, H=42mm
  • Power requirement 400W
  • Support 4K at 60 Hz via two HDMI
    Current graphic cards do not support HDMI specification, it is required to use two HDMI output to support Ultra HD resolution - 4096 x 2160 at 60 Hz. With a monitor features HDMI dual mode, users can experience an impressive 4K HD enjoyment with the latest technological advancements!
  • Gigabyte custom-designed 10 cm cooler
    As opposed to the stereotype, Gigabyte is able to maximize fan size to 10 cm with the latest cooling design. With a 10 cm fan, the card is virtually silent that its noise level runs much lower.
  • Gold plated HDMI
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
  • Up to 4 displays on a single card
    Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
  • OC GURU II
    Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
Gigabyte GV-N750OC-1GI - graphics card - GF GTX 750 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
1 GB GDDR5
Core Clock
1059 MHz
Boost Clock
1137 MHz
Effective Memory Clock
5 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
API Supported
DirectX 11.2, OpenGL 4.4
4.2 cm x 18.5 cm x 13.5 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1059 MHz
Boost Clock
1137 MHz
Process Technology
28 nm
Max Resolution
4
Interfaces Details
API Supported
Nvidia PhysX-Ready, Ultra Durable 2, Nvidia 3D Vision technology, GIGABYTE custom-designed 100 mm cooler, Gold plated HDMI, Adaptive V-Sync, NVIDIA GPU Boost, OC Guru II
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5 GHz
Bus Width
128-bit
Required Power Supply
400 W
Software Included
OC Guru ll
4.2 cm
18.5 cm
13.5 cm
