Gigabyte GeForce GTX 660 980MHz 2GB PCI-Express 3.0 HDMI Rev 2
Quicklinx: 9F8PWS00 Mfr#: GV-N660WF2-2GD-REV2.0
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
WindForce 2X parallel-inclined fin design is equipped with 2 ultra quiet PWM fans and two copper heat pipes to enlarge air channel on the graphics card vents and creates a more effective airflow system in chassis.
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programers to speed up those performance hungry computing applications.
  • WindForce 2X anti-turbulence-parallel inclined
  • PhyX technology
    NVIDIA PhysX is the next big thing in gaming! The excellent way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor.
  • CUDA technology
  • SLI technology
    Delivers up to 2x the performance of a single GPU configuration for unparalleled gaming experiences by allowing two graphics cards to run in parallel. The must-have feature for performance PCI Express graphics, SLI dramatically scales performance on 60 top PC games.
  • NVIDIA 3D Vision
    NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
Gigabyte GV-N660WF2-2GD (rev. 2.0) - graphics card - GF GTX 660 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 660
2 GB GDDR5
Core Clock
980 MHz
Effective Memory Clock
6.008 GHz
Memory Interface
192-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
HDMI , DisplayPort , DVI-D , DVI-I (dual link)
API Supported
DirectX 11.1, OpenGL 4.3
4.2 cm x 25.63 cm x 13.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
980 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Ultra Durable VGA, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 2x, Dual Fan Design, Nvidia SLI ready
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
192-bit
Required Power Supply
450 W
RoHS
4.2 cm
25.63 cm
13.1 cm
