Gigabyte offers the exclusive WINDFORCE 2x 100 mm fansink equipped with "Triangle Cool" technology to reach a better cooling performance. The patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans.
The instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, GPU voltage, memory voltage, OSD, online support and update driver, BIOS directly.
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections -
Gigabyte offers the exclusive WINDFORCE 2x 100 mm fansink equipped with "Triangle Cool" technology to reach a better cooling performance. The patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. -
OC GURU ll
The instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, GPU voltage, memory voltage, OSD, online support and update driver, BIOS directly. -
PhysX technology
NVIDIA PhysX is the next big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor. -
CUDA technology
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programers to speed up those performance hungry computing applications. -
SLI technology
Delivers up to 2x the performance of a single GPU configuration for unparalleled gaming experiences by allowing two graphics cards to run in parallel. The must-have feature for performance PCI Express graphics, SLI dramatically scales performance on 60 top PC games. -
NVIDIA 3D Vision
NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
- Gigabyte GV-N660OC-2GD - graphics card - GF GTX 660 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 660
- Memory
- 2 GB GDDR5
- Core Clock
- 1033 MHz
- Boost Clock
- 1098 MHz
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- Max Monitors Supported
- 4
- DVI-I (dual link) , DVI-D , HDMI , DisplayPort
- API Supported
- DirectX 11, OpenGL 4.2
- 4.2 cm x 25.63 cm x 13.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1033 MHz
- Boost Clock
- 1098 MHz
- Process Technology
- 28 nm
- Max Resolution
- 2560 x 1600
- 4
- API Supported
- Nvidia SLI Multi-GPU Technology, Dual Slot Fan Cooler, Ultra Durable VGA, Nvidia CUDA technology, Nvidia PhysX-Ready, Ultra Durable 2, Nvidia 3D Vision technology, Nvidia 3D Vision Surround Ready, GIGABYTE WindForce 2x, Dual Fan Design, 10 cm Large PWM Fan, Triangle Cool Technology, Gold plated HDMI, TXAA, FXAA, NVIDIA Adaptive Vertical Sync, OC Guru II
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 450 W
- RoHS
- 4.2 cm
- 25.63 cm
- 13.1 cm
