Gigabyte GeForce GTX 560 Ti 448 Cores 732MHz 1280MB PCI-Express HDMI
Quicklinx: 7V8GWS00 Mfr#: GV-N560448-13I
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
New! With WINDFORCETM 3X Cooler! NVIDIA GeForce GTX 560 Ti 448 Cores GPU
  • Core/Mem clock: 732/3800 MHz
  • WINDFORCETM 3X w/ larger vapor chamber & two 8mm heat pipes
  • Features DisplayPort/ DVI-I1/ DVI-D1/ HDMI
  • 13.4% performance better than stock GTX 560 Ti
  • Powered by NVIDIA GeForce GTX 560 Ti 448 Cores GPU
  • 448 CUDA Core
  • Microsoft DirectX 11 and OpenGL 4.1 support
  • Supports PCI Express 2.0 interface
  • Support NVIDIA Surround, 3D Vision, PhysX, CUDA,, and Pure Video HD Technology
  • Support 3 way SLI
  • 550 Watt or greater power supply recommended
Specification
  • GPU: GeForce GTX 560 Ti 448 Cores
  • Core Clock: 732 MHz
  • Memory Clock: 3800 MHz
  • Shader Clock: 1464 MHz
  • Memory Size: 1280 MB
  • Bus Type: PCI Express 2.0
  • Memory Bus: 320-bit
  • Stream Processors: 448
  • Memory type: 32Mx32 GDDR5
  • DirectX 11: Yes
  • Minimum System Power Requirement: 550W
  • GPU temperature 5% - 10% down
    Ultra durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. Gigabyte ultra durable VGA can lower GPU temperature by 5% to 10%.
  • Overclocking capability 10% - 30% up
    Ultra durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. Gigabyte ultra durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
  • Power switching loss 10% - 30% down
    Ultra durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. Gigabyte ultra durable VGA can lower power switching loss by 10% to 30%.
  • WindForce 3x - vapor chamber-outward inclined
    WindForce 3x 3D-inclined fin design is Gigabyte's first generation triple-fan solution. It features 3 ultra quiet PWM fans, three copper heat pipes and a unique vapor chamber to strengthen the speed of heat dissipation.
  • Gold plated HDMI
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
  • CUDA technology
    NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications.
  • PhysX technology
    NVIDIA PhysX is the next big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor.
  • SLI technology
    It delivers up to 2x the performance of a single GPU configuration for unparalleled gaming experiences by allowing two graphics cards to run in parallel. The must-have feature for performance PCI Express graphics, SLI dramatically scales performance on 60 top PC games.
  • NVIDIA 3D Vision
    NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
Gigabyte GV-N560448-13I - graphics card - GF GTX 560 Ti - 1.25 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
1.25 GB GDDR5
Core Clock
732 MHz
CUDA Cores
448
Effective Memory Clock
3.8 GHz
Shader Clock
1464 MHz
Memory Interface
320-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
2
DisplayPort , DVI-I (dual link) , DVI-D (dual link) , HDMI , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.1
4.3 cm x 28 cm x 13.7 cm
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
732 MHz
CUDA Cores
448
Shader Clock
1464 MHz
Max Resolution
2560 x 1600
2
API Supported
Nvidia SLI Multi-GPU Technology, heatpipe cooler (with fan), Ultra Durable VGA, Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, GIGABYTE WindForce 3x, GIGABYTE Easy Boost
Size
1.25 GB
GDDR5 SDRAM
Effective Clock Speed
3.8 GHz
Bus Width
320-bit
Required Power Supply
550 W
Additional Requirements
Two 6-pin power connectors
RoHS
4.3 cm
28 cm
13.7 cm
