The WINDFORCE 3X cooling system features 3 pure copper composite heat-pipes, special fin architecture, unique blade fan design, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming.
The WINDFORCE 3X cooling system features 3 pure copper composite heat-pipes, special fin architecture, unique blade fan design, together delivering an effective heat dissipation capacity for higher performance at lower temperatures. -
Unique blade fan design
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans. -
3D active fan
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. -
Stylish metal back plate
The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product. -
Smart power LED indicators
Be alert when PCI-E voltage is unstable with the smart power LED indicator.
- Gigabyte GeForce GTX 1080 WINDFORCE OC 8G - graphics card - GF GTX 1080 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080
- Memory
- 8 GB GDDR5X
- Core Clock
- 1657 MHz
- Boost Clock
- 1797 MHz
- Effective Memory Clock
- 10.01 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Resolution Details
- DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4.1 cm x 28 cm x 11.4 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1657 MHz
- Boost Clock
- 1797 MHz
- Process Technology
- 16 nm
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- 4
- API Supported
- Ultra Durable VGA, LED indicator, MSI Solid Capacitor, GIGABYTE WindForce 3x, Three Fans Cooler, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, 8+2 Phase PWM Design, Nvidia GeForce GTX VR Ready
- Size
- 8 GB
- Technology
- GDDR5X SDRAM
- Effective Clock Speed
- 10.01 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Included Accessories
- Backplate
- Software Included
- XTREME Engine Utility
- 4.1 cm
- 28 cm
- 11.4 cm
