Gigabyte GeForce GTX 1080 Ti AORUS 11GB GDDR5X PCIe3.0 Graphics Card
Quicklinx: CV87WS00 Mfr#: GV-N108TAORUS-11GD
AORUS graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA Pascal GPU architecture, AORUS graphics card brings you incredible gaming experience.
  • RGB fusion
    With 16.8M customizable color options and numerous lighting effects, you could now choose the right scheme for your gaming rig through AORUS graphics engine.
  • So easy to VR
    AORUS VR Link features 1 extra front-facing and 2 rear HDMI ports, letting you connect a VR device and up to 2 HDMI monitors at the same time without having to swap cables, so you can flexibly set up a display configuration that best fits your gaming needs.
  • Multi display configuration support
    AORUS VR Link supports various combinations of displays without any adaptors required.
  • Protection metal back plate
    Glorious black metal back plate provides the solid protection, strengthens the structure and inspires the passion for gaming.
  • Boost game performance via SLI technology
    Supports for 2-way SLI configuration, AORUS SLI HB (High Bandwidth) bridge doubles the available transfer bandwidth bridge compared to the previous generation to deliver ultimate experience at 4K gameplay or surround gaming. The AORUS SLI bridge features 16.8M customizable color lighting and numerous effects, you could also synchronize the lighting with the graphics cards through AORUS Engine utility.
  • AORUS all-around cooling solution
    AORUS provides the all-around cooling solution for all key components of the graphics card. It concerns not only GPU but also VRAM and MOSFET, to ensure a stable overclock operation and longer life. On the front side, the large copper base plate dissipates most heat from the GPU and VRAM. On the back side, the copper back plate dissipates the heat from the GPU back side. All other key components are taken care of very well by the WINDFORCE cooling module.
  • Large copper base plate
    With direct contact to the GPU and VRAM, the large copper base plate combines the composite heat pipes to efficiently transfer heat generated from the interior cores to the heat sink.
  • Advanced copper back plate cooling
    Excessive heat from GPU not only gets dissipated utilizing the massive cooling module in the front but also through the back side with a copper plate, providing a well-rounded thermal solution for the GPU.
  • PCB coating for best protection
    Dust -resistant shields the circuit board from dust, insects, dropped screws, drill shavings, and abrasion. Moisture resistance prevents unwanted conduction paths and board damage. Corrosion resistance protects boards from environmental contaminants, such as salt spray, humidity, and corrosion.
  • Friendly PCB design thanks to fully automated production process
    Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
Gigabyte AORUS GeForce GTX 1080 Ti 11G - graphics card - GF GTX 1080 Ti - 11 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080 Ti
11 GB GDDR5X
Core Clock
1594 MHz
Boost Clock
1708 MHz
Effective Memory Clock
11010 MHz
Memory Interface
352-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI , DVI-D (dual link) (not available, if VR headset connected) , 2 x HDMI (available, if VR headset connected)
API Supported
DirectX 12, OpenGL 4.5
5.5 cm x 29.3 cm x 14.2 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1594 MHz
Boost Clock
1708 MHz
Max Resolution
4
Interfaces Details
API Supported
Nvidia 2-way SLI ready, Dual ball Bearing Fan, NVIDIA GameWorks, Titan X-grade Chokes, GIGABYTE WINDFORCE Stack 3x cooling system, AORUS Graphics Engine, AORUS VR Link
Size
11 GB
GDDR5X SDRAM
Effective Clock Speed
11010 MHz
Bus Width
352-bit
Required Power Supply
600 W
Additional Requirements
2 x 8 pin PCI Express power connector
5.5 cm
29.3 cm
14.2 cm
