Gigabyte GeForce GTX 1060 mini-ITX OC 6GB GDDR5 PCIe Graphics Card
Quicklinx: CCPYWS00 Mfr#: GV-N1060IXOC-6GD
Equipped with 2 pure copper heat pipes and unique-blade fan with 3D active functionality, and heat pipes direct touch technology, the cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise.
  • Unique blade fan design
    The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow.
  • 3D active fan
    The semi-passive fans will remain off, when the GPU is under a set loading or temperature for low-power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
  • Composite heat pipes
    The composite heat pipes combine both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases cooling capacity.
  • Heat pipe direct touch
    The pure copper heat pipes are shaped to maximize the direct contact area to the GPU.
  • Ultra-durable graphic components
    Engineered with the high-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan.
Gigabyte GeForce GTX 1060 Mini ITX OC 6G - OC Edition - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1556 MHz
Boost Clock
1771 MHz
Effective Memory Clock
8.008 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 16.9 cm x 13.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1556 MHz
Boost Clock
1771 MHz
Process Technology
16 nm
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Ultra Durable VGA, NVIDIA G-Sync ready, NVIDIA GameWorks, GIGABYTE custom-designed 90 mm cooler, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
Software Included
XTREME Engine Utility
3.7 cm
16.9 cm
13.1 cm
