GEFORCE GTX 1050
ESSENTIAL GEAR FOR EVERY GAMER
Everyone deserves great gaming. That’s why we created the fast, powerful GeForce® GTX 1050. Now, you can turn your PC into a true gaming rig, powered by NVIDIA Pascal™—the most advanced GPU architecture ever created. It’s loaded with innovative NVIDIA Game Ready technologies that let every gamer experience the latest titles in their full glory. #GameReady.
Powered by GeForce® GTX 1050
Integrated with 2GB GDDR5 128bit memory
90mm Fan Design
Support up to 8K display @60Hz
Core
Boost: 1493 MHz/ Base: 1379 MHz in OC Mode
Boost: 1455 MHz/ Base: 1354 MHz in Gaming
GIGABYTE custom-designed 90 mm fan cooler
GIGABYTE custom-designed 90 mm fan cooler, with air flow optimized cover and aluminum base. The cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise. -
3D active fan
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle. -
One-click super overclocking
With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment. -
Ultra cooling
Lower RDS(on) MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging at extremely low temperature. -
Low power loss
Metal Choke hold energy much longer than common iron-core chokes at high frequency, thus effectively reduce core energy loss and EMI interference. -
Longer life
Lower ESR Solid Capacitors ensure better electronic conductivity for excellent system performance and longer lifespan.
- Gigabyte GeForce GTX 1050 D5 2G - graphics card - NVIDIA GeForce GTX 1050 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- Memory
- 2 GB GDDR5
- Core Clock
- 1379 MHz
- Boost Clock
- 1493 MHz
- Effective Memory Clock
- 7.008 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Resolution Details
- DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
- Max Monitors Supported
- 3
- Interfaces Details
- DVI-D (dual link) , DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3 cm x 17.2 cm x 11.3 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1379 MHz
- Boost Clock
- 1493 MHz
- Process Technology
- 16 nm
- Max Resolution
- 7680 x 4320 at 60 Hz
- 3
- API Supported
- Ultra Durable 2, NVIDIA G-Sync ready, NVIDIA GameWorks, 90mm Unique blade fan design, NVIDIA Pascal GPU technology
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.008 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 300 W
- Software Included
- GeForce Experience, XTREME Engine Utility
- 3 cm
- 17.2 cm
- 11.3 cm
