Product
Brand
Gigabyte GeForce GT 730 902MHz 2GB GDDR5 PCI-Express 2.0 16 HDMI
Quicklinx: 9NXJWS00 Mfr#: GV-N730D5-2GI
  • High-Definition Multimedia Interface (HDMI)
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE is again setting a new standard by using ferrite core chokes, low RDS (on) MOSFET and lower ESR solid capacitors, providing the stability and reliability from their high-end graphics solution. In addition, GIGABYTE Ultra Durable 2 Edition graphics card features a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
Gigabyte GV-N730D5-2GI - graphics card - GF GT 730 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x8
Graphics Engine
NVIDIA GeForce GT 730
2 GB GDDR5
Core Clock
902 MHz
Effective Memory Clock
5 GHz
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Monitors Supported
3
DVI-D (dual link) , VGA , HDMI
API Supported
DirectX 11.2, OpenGL 4.4
3 cm x 17.7 cm x 12 cm
Graphics card
Bus Type
PCI Express 2.0 x8
Graphics Engine
Core Clock
902 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
3
API Supported
Nvidia PhysX-Ready, Ultra Durable 2, GIGABYTE custom-designed 100 mm cooler, Gold plated HDMI, NVIDIA Adaptive Vertical Sync, OC Guru II
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5 GHz
Bus Width
64-bit
Required Power Supply
300 W
Software Included
OC Guru ll
3 cm
17.7 cm
12 cm
