Gigabyte GeForce GT 710 2GB DDR3 Dual-DVI-D HDMI DX12 Graphics Card
Quicklinx: BWG5WS00 Mfr#: GV-N710D3-2GL
• Powered by NVIDIA GeForce GT 710 GPU
• Integrated with the first 2048MB DDR3 memory and 64-bit memory interface
• Core Clock: 954MHz
• Features Dual-link DVI-D / D-Sub / HDMI
• Support PCI Express 2.0 x8 bus interface
• Recommended system power supply requirement: 300W
Low Profile Design
Low profile design allows space-saving installation and easier for building your compact PC system.
Ultra Durable 2
Ultra Cooling - Low RDS(on) MOSFET Design
Low Power Loss - Ferrite Core Choke Design
Longer Life - All-Solid Capacitor Design
Gold Plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections
OC GURU II
Brand-new intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
Gigabyte GV-N710D3-2GL - graphics card - GF GT 710 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x8
Graphics Engine
2 GB DDR3
Core Clock
954 MHz
Effective Memory Clock
1.8 GHz
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Monitors Supported
2
Interfaces Details
DVI-D (dual link) , VGA , HDMI
API Supported
DirectX 12, OpenGL 4.5
2.1 cm x 14.4 cm x 6.8 cm
3-year warranty
Bus Type
PCI Express 2.0 x8
Graphics Engine
Core Clock
954 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
2
Interfaces Details
API Supported
Nvidia GeForce 3D Vision Ready, Nvidia PhysX-Ready, Ultra Durable 2, solid state capacitors, Gold plated HDMI, NVIDIA Adaptive Vertical Sync, OC Guru II
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
64-bit
Required Power Supply
300 W
Software Included
OC Guru ll
2.1 cm
14.4 cm
6.8 cm
Limited warranty - 3 years
