Gigabyte GC-WB867D-I WLAN Bluetooth4.0 WiFi Expansion Card
Quicklinx: C9P1WS00 Mfr#: GC-WB867D-I
  • Bluetooth 4.0
  • IEEE 802.11n
Delivers dramatically faster Wi-Fi speeds (up to 867 Mbps) than 802.11n, with more bandwidth per stream 433 Mbps), more capacity for more users (extended channel bonding 80 MHz), broader coverage and better battery life (more data transmit efficiencies reduce power consumption).
The motherboard also includes an exclusive PCIe expansion card that offers support for the Bluetooth 4.0 and IEEE 802.11ac Wi-Fi connectivity. The Bluetooth 4.0 standard includes Smart Ready technology that is debuting on mobile devices including the Apple iPhone. This means that transferring important content from your smart phone or tablet is easier and faster than ever.
  • More speed better coverage larger capacity 802.11ac, dual band, 80 MHz, 2 x 2
  • Support Intel Wireless Display (Intel WiDi)
    Intel Wireless Display let you enjoy wireless life at home and at work. Through adapters, you can easily experience your PC on you TV or projectors, Broadcasting Promotion and commercials with more flexibility and efficiency.
  • Exclusive Bluetooth 4.0/Wi-Fi expansion card
Gigabyte GC-WB867D-I (rev. 1.0) - network adapter - PCIe
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Bluetooth 2.1 EDR, Bluetooth 3.0 HS, Bluetooth 4.0, Wi-Fi 5
Data Transfer Rate
867 Mbps
Network / Transport Protocol
PAP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11ac
Network adapter
Plug-in card
PCI Express x1
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 2.1 EDR, Bluetooth 3.0 HS, Bluetooth 4.0, IEEE 802.11ac
Data Transfer Rate
867 Mbps
PAP
Wi-Fi Multimedia (WMM) support, Ad-Hoc Mode, Wi-Fi Protected Setup (WPS), Smart Ready technology, 802.1x authentication
Aerial
Antenna
External detachable
Antenna Qty
1
Encryption Algorithm
LEAP, 128-bit WEP, 64-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA2, AES-CCMP
UL, cUL, CB, IEC 60950-1
Software Included
