Gigabyte GB-XM12 BRIX Intel Core i3-3227U Ultra Compact PC
Quicklinx: 9F8NWS00 Mfr#: GB-XM12
  • IEEE 802.11n
  • Core i3
Challenging the essence of how Gigabyte defines a desktop PC, Gigabyte engineers have developed an ultra compact PC with a stylish design based around an anthracite aluminum frame and glass surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. With a broad choice of processors covering the entire performance spectrum, the BRIX sets a standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications. Bundled with a VESA bracket, the BRIX can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This makes it simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
  • Redefining the desktop PC
  • Dual display
  • VESA support
Gigabyte BRIX GB-XM12-3227 (rev. 1.0) - mini PC - Core i3 3227U 1.9 GHz - 0 GB - no HDD
PC barebone - mini PC
1 x Intel Core i3 (3rd Gen) 3227U / 1.9 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
0 GB (installed) / 16 GB (max) - DDR3 SDRAM
Storage Controller
SATA
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 4000
GigE, 802.11b/g/n
AC 120/230 V
OS Provided
No operating system
10.76 cm x 11.44 cm x 2.99 cm
PC barebone
Product Form Factor
Mini PC
Processor / Chipset
CPU
Clock Speed
1.9 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Mobile Intel HM77 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
0 GB / 16 GB (max)
DDR3 SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Ethernet Controller
Realtek RTL8111E
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Slots
1 (total) / 1 (free) x mSATA , 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Half Mini Card
2 x USB 3.0 (1 front, 1 rear) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet)
VESA wallmount adapter
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
AC 120/230 V
Operating System / Software
OS Provided
No operating system
10.76 cm
11.44 cm
2.99 cm
