Gigabyte GA-Z270X-Designare LGA1151 Intel Z270 DDR4 ATX
Quicklinx: CSQSWS00 Mfr#: GA-Z270X-Designare
GIGABYTE's 200 series motherboards boast the advanced LED system. With more customizability than ever and a convenient and intuitive UI, you'll have a blast making your GIGABYTE your own. LED enthusiasts now have even more options with the ability to customize multiple zones independently. For a more functional use, the bright and vibrant LEDs can be configured to display the PC's temperature or load. For even more LED goodness RGBW strips are now supported for more true and vibrant whites.
  • Surround lighting
    Now offering more LED customizations than ever, users can truly adapt their PC to represent their lifestyle. With full RGB support and a redesigned RGB Fusion application, the user has complete control over the LEDs which surround the motherboard.
  • Swappable Overlay for Accent LED
    GIGABYTE brings even more color and life to your system with an Accent LED Overlay. This overlay complements the RGB Fusion technology in GIGABYTE motherboards adding more flare and style to your gaming machine. With the swappable overlay users can utilize different patterns and designs to make their system their own.
  • Independently programmable onboard pin header for RGBW LED strips
    Not bright enough? You can install standard external RGB or RGBW light strips on the RGBW pin header and control its color from the RGB Fusion software. With RGBW light strips that have a dedicated white color LED, you can have brighter and more vibrant colors.
  • Smart Fan 5
    With Smart Fan 5 users can ensure that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers that support both PWM and Voltage mode fans have been introduced to make the motherboard more liquid cooling friendly.
  • Interoperable sensors and fans
    Each fan can be customized to operate at different speeds according to any defined temperature source input.
  • Enhanced BIOS interface
    The enhanced BIOS interface also has the advanced features seen in the Smart Fan 5 UI, such as: the ability to set triggers based on different temperature sensors on the board, fan curve definition and the temperature interval setting, which can prevent fan rotation noise caused by sudden temperature change.
  • Front USB 3.1 Gen 2 header
    Equipped with next-generation connectivity onboard GIGABYTE motherboards already support the cases of the future. Onboard headers for USB 3.1 makes access convenient when connecting a USB 3.1 drive or charging your mobile device.
  • Smart headphone amp
    Automatically detects impedance of your head-worn audio device, whether earbuds or high-end headphones to provide optimal audio dynamics - preventing issues such as low volume and distortion.
  • High-end audio capacitors
    GIGABYTE motherboards use high-end audio capacitors. These high-quality capacitors help deliver high-resolution and high-fidelity audio to provide realistic sound effects for gamers.
  • Intel GbE LAN with cFosSpeed Internet accelerator networking
    Intel GbE LAN features cFosSpeed, a network traffic management application which helps to improve network latency and maintain low ping times to deliver better responsiveness in crowded LAN environments.
  • PCIe Gen3 x4 M.2
    GIGABYTE' M.2 solution offers considerably faster storage performance and support for both PCIe and SATA interfaces for M.2 SSD devices.
  • 2-way SLI / 3-way CrossFire multi-graphics
    Multi-graphics configuration offers better graphics performance for gaming enthusiasts who demand high frame rates without compromising on resolution.
Gigabyte GA-Z270X-DESIGNARE - 1.0 - motherboard - ATX - LGA1151 Socket - Z270
Motherboard - ATX
Chipset Type
Intel Z270
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4 unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA Express port, 1 x M.2, 1 x U.2 port
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (1 x USB 3.1 Gen 2 + 2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z270
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC1220
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (x8 mode if PCI Express 3.0 x8 slot is occupied)) , 1 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 3.0 x16 (x4 mode (x1 mode if PCI Express 3.0 x1 slot is occupied)) , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 2 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x U.2
1 x DVI-D , 1 x HDMI , 1 x USB-C Gen2 , 1 x USB 3.1 Gen 2 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x USB 3.1 Gen 2 - header , 1 x audio - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Diagnostic LEDs, Q-Flash, AutoGreen, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, Easy RAID Installer, Black Solid Capacitors, Game Boost, Ultra Durable PCIe Metal Shielding, GIGABYTE Double Locking Bracket, Ultra Durable Memory Armor, Anti-Sulfur Design, G-Connector, GIGABYTE USB DAC-UP 2, Intel Optane Memory Ready, GIGABYTE Smart Fan 5, RGB FUSION, Ultra Durable PCIe Armor, RGBW LED strips support
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE Smart Fan 5, GIGABYTE 3D OSD
Plug and Play
30.5 cm
24.4 cm
