Product
Gigabyte GA-Z270N-WIFI LGA1151 Intel Z270 DDR4 ITX
Quicklinx: CLPNWS00 Mfr#: GA-Z270N-WIFI
  • IEEE 802.11n
  • Bluetooth 4.0
  • Bluetooth 3.0
Smart Fan 5
With Smart Fan 5 users can ensure that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers that support both PWM and Voltage mode fans have been introduced to make the motherboard more liquid cooling friendly.
  • 2 Fan Pin Headers.
  • 4 Temperature Sensors.
  • All Fan Pin Headers Upgraded to Hybrid Fan Headers.
  • Supports High Current Fans up to 24W (2Ax12V) with Over-Current Protection.
  • Intuitive UI for Fan Control.
All Hybrid Fan Pin Headers
  • Hybrid Fan Headers detect whether the cooling device uses PWM or Voltage mode and automatically switches settings accordingly.
  • Supports up to 2 amps with built-in overcurrent protection—a must for high-end high current fans.
Gigabyte GA-Z270N-WIFI - 1.0 - motherboard - mini ITX - LGA1151 Socket - Z270
Motherboard - mini ITX
Chipset Type
Intel Z270 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB-C Gen1 1 x USB-C Gen 1 + 4 x USB 3.1 Gen 1 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel Z270 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3800 MHz (O.C.), 3666 MHz (O.C.), 3866 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC1220
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x M.2 socket
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x DVI-D , 2 x HDMI , 2 x LAN (Gigabit Ethernet) , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x USB-C Gen1 , 4 x USB 3.1 Gen 1 , 1 x PS/2 keyboard / mouse
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x speaker - header , 1 x SPDIF out - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Q-Flash, AutoGreen, Intel Extreme Memory Profile (XMP) support, 15µ Gold Contact, On/Off Charge, Easy RAID Installer, 3TB+ Unlock, Black Solid Capacitors, Clear CMOS Button, Game Boost, Ultra Durable PCIe Metal Shielding, GIGABYTE Double Locking Bracket, Anti-Sulfur Design, Intel Optane Memory Ready, GIGABYTE Smart Fan 5
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE Smart Fan 5, GIGABYTE 3D OSD
Plug and Play
17 cm
17 cm
