Gigabyte GA-H110M-S2PV DDR3 Intel H110 S1151 PCIe3.0 USB3.0 microATX
Quicklinx: BPSJWS00 Mfr#: GA-H110M-S2PV DDR3
GIGABYTE 100 series motherboards support the 6th generation Intel Core processors, a 14nm desktop CPU which features improved performance, power efficiency and support for DDR3 memory, bringing cutting edge features and ultimate performance to your next PC build.
Realtek GbE LAN features cFosSpeed, a network traffic management application which helps to improve network latency, maintain low ping times to delivery better responsiveness in a crowded LAN environments. Realtek GbE consumes significant less power when it's in idle state in comparison with others.
With superfast transfer rates of up to 5 Gbps, users are able to experience an almost a 10x improvement over USB 2.0. Additionally, backwards compatibility with USB 2.0 assures users legacy USB 2.0 devices will still work.
GIGABYTE Ultra Durable motherboards feature GIGABYTE DualBIOS, an exclusive technology from GIGABYTE that protects arguably one of your PC's most crucial components, the BIOS. GIGABYTE DualBIOS means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
Gigabyte GA-H110M-S2PV DDR3 - motherboard - micro ATX
Motherboard - micro ATX
Processor Socket
1
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Max Processors Qty
1
Supported RAM
Dual channel memory architecture
Audio
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Power Connectors
24-pin main power connector
BIOS Type
AMI
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
