Gigabyte GA-H110M-S2H Intel H110 S1151 DDR4 PCIe3.0 USB3.0 microATX
Quicklinx: BPSGWS00 Mfr#: GA-H110M-S2H
Processor Socket: LGA1151 Socket
Chipset: Intel H110 Express
Graphics: Graphics adapter (CPU required)
Form Factor: Micro ATX
Memory Support: DDR4 SDRAM
Hurry, only 1 left in stock!
£44.48 ex VAT
£53.37 inc VAT
Express delivery Order within the next 20 hours for delivery on Wednesday
GIGABYTE 100 series motherboards support the latest 6th Generation Intel Core processors, a 14nm desktop CPU which features improved performance, power efficiency and support for DDR4 memory, bringing cutting edge features and ultimate performance to your next PC build.
Realtek GbE LAN features cFosSpeed, a network traffic management application which helps to improve network latency, maintain low ping times to delivery better responsiveness in a crowded LAN environments. Realtek GbE consumes significant less power when it's in idle state in comparison with others.
With superfast transfer rates of up to 5 Gbps, users are able to experience an almost a 10x improvement over USB 2.0. Additionally, backwards compatibility with USB 2.0 assures users legacy USB 2.0 devices will still work.
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE motherboards provide native 4K support with integrated Intel HD Graphics via HDMI.
  • GIGABYTE Ultra Durable Motherboards
  • High Quality Onboard Audio Design
    Delivers high quality sound resolution and sound expansion to create the most realistic sound effects for professional users.
  • High Definition Digital Outputs
    Enjoy true HD display capability using the most commonly integrated digital output technologies on today's HD displays and TVs.
  • Realtek GbE LAN with cFosSpeed Internet Accelerator Software
  • APP Center
    GIGABYTE APP Center gives you easy access to a wealth of GIGABYTE APPs that help you get the most from your GIGABYTE motherboard. Using a simple, unified user interface, GIGABYTE APP Center allows you to launch all GIGABYTE APPs installed on your system.
  • Cloud Station
    GIGABYTE Cloud Station is composed of several GIGABYTE unique apps that allow your smart phones/tablet devices to communicate, share resources, and control your desktop PC via a wireless connection.
  • USB 3.0 Ports Onboard
  • 4K Ultra HD support
  • HDMI
    HDMI is a High-Definition Multimedia Interface which provides up to 5Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI is compatible with HDCP (High-bandwidth Digital Content Protection), allowing the playback of Blu-ray/HD DVD and other protected media content.
Gigabyte GA-H110M-S2H - 1.0 - motherboard - micro ATX - LGA1151 Socket - H110
Motherboard - micro ATX
Chipset Type
Intel H110 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
Storage Ports
4 x SATA-600
USB / FireWire Ports
USB 3.0 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H110 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC, ECC (operate in non-ECC mode)
Registered or Buffered
Unbuffered
Dual channel memory architecture, supported ECC modules operate in non-ECC mode
Graphics
512 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
2 x USB 3.0 , 4 x USB 2.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x HDMI
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Q-Flash, AutoGreen, Ultra Durable, Easy RAID Installer, 4K Ultra HD ready, Audio Noise Guard with Path Lighting, GIGABYTE Smart Switch, Intel Small Business Basics support
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup
Plug and Play, ACPI 5.0
22.6 cm
17.4 cm
Brand: Gigabyte
Price Range Ex VAT: 0 - 50
