Gigabyte GA-C1037UN Intel Celeron 1037U Dual Core NM10 mITX
Quicklinx: 9F89WS00 Mfr#: GA-C1037UN-EU
Gigabyte Ultra Durable 4 Classic motherboards embrace a range of exclusive features that guarantee DIY PC builders the absolute best protection for their PC, with built-in features that prevent common malfunction threats users encounter on a day-to-day basis.
  • Humidity protection
    Humidity can play havoc on a motherboard's circuitry. Gigabyte's glass Fabric PCB design helps protect against electrical shorts due to humidity by reducing the gaps in spacing between PCB filaments.
  • Electrostatic protection
    Gigabyte Ultra Durable 4 Classic motherboards feature high resistance ICs which help protect the motherboard against electrostatic discharge.
  • Power failure protection
    Permanent damage from power surge or failure during BIOS update, can be avoided with Gigabyte DualBIOS, which automatically enables a secondary, back up BIOS.
  • UEFI DualBIOS technology
    With a superior graphical interface capable of 32-bit color imaging and fluid user-friendly mouse navigation, UEFI DualBIOS makes BIOS configuration an exciting experience for novice and experienced users alike. UEFI BIOS also brings native support for large hard drives on 64-bit operating systems.
  • All solid capacitors
    Gigabyte Ultra Durable motherboards are equipped with solid capacitors which provide the stability, reliability and longevity essential to meet the power needs of high-end processor and other components running today's most demanding applications and games.
  • HDMI
    HDMI is a High-Definition Multimedia Interface which provides up to 2.5 Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI is compatible with HDCP (High-bandwidth Digital Content Protection), allowing the playback of Blu-ray/HD DVD and other protected media content.
  • On/Off Charge technology
    Gigabyte On/Off Charge technology allows you to charge your iPhone, iPad and iPod Touch regardless of whether your PC is on, in standby mode or even off. A derivative of Gigabyte's highly acclaimed 3x USB power feature, On/Off Charge enables devices to draw more current from Gigabyte motherboard USB ports than standard USB ports allow, so that charging from your PC can be as fast as with a charger.
Gigabyte GA-C1037UN-EU - 1.0 - motherboard - mini ITX - Intel Celeron 1037U - NM70
Motherboard - mini ITX
Intel Celeron 1037U / 1.8 GHz (Dual-Core)
Chipset Type
Mobile Intel NM70 Express
Processor Socket
1
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3
Storage Ports
1 x SATA-600, 2 x SATA-300, 1 x eSATA-300, 1 x ATA-133
USB / FireWire Ports
4 x USB 2.0 + (4 x USB 2.0 via headers)
Graphics
Intel HD Graphics
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
2 x Gigabit Ethernet
Cache Memory
L3 - 2 MB
Chipset Type
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz
Dual channel memory architecture
Graphics
Graphics Controller
Intel HD Graphics
1 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Expansion Slots
2 x DIMM 240-pin (1.5 V) , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 1 x 7pin Serial ATA - 1 devices , SATA-300 -connectors: 2 x 7pin SATA, 1 x 7pin eSATA - 3 devices , JMicron JMB368: ATA-133 -connectors: 1 x 40pin IDC - 2 devices
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x serial , 1 x HDMI , 4 x USB 2.0 , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x audio - header , 4 x USB 2.0 - header , 1 x parallel - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, CPU fan tachometer, chassis fan tachometer, system voltage
Hardware Features
DualBIOS, Q-Flash, AutoGreen, All-Solid Capacitor motherboard Design, On/Off Charge, Ultra Durable 4 Classic, Intel Smart Connect Technology, Clear CMOS Button
Software Included
Norton Internet Security, @BIOS, Xpress Install
ACPI 2.0a, Energy-Related Products (ErP) Lot 6
17 cm
17 cm
