Gigabyte GA-B250N-Phoenix WIFI LGA1151 Intel B250 DDR4 ITX
Quicklinx: CLQ1WS00 Mfr#: GA-B250N-Phoenix WIFI
  • Supports 7th/6th Generation Intel® Core™ Processors.
  • Dual Channel Non-ECC Unbuffered DDR4, 2 DIMMs.
  • Fast USB 3.1 Gen 2 with USB Type-C™ and Type-A.
  • 802.11ac Dual Band 867Mbps wireless supports MU-MIMO and BT4.2.
  • Intel® GbE LAN with cFosSpeed Internet Accelerator Software.
  • RGB FUSION LED Light Show design.
  • Ultra-Fast M.2 with PCIe Gen3 x4 & SATA interface.
  • Smart Fan 5 features Multiple Temperature Sensors and Hybrid Fan Headers.
  • GIGABYTE UEFI DualBIOS™.
  • APP Center Including Cloud Station™ Utility.
RGB Fusion: Set the Colour that Matches Your Style
GIGABYTE's 200 series motherboards boast the most advanced LED system in the market today. With more customizability than ever and a convenient and intuitive UI thanks to the RGB Fusion App, you’ll have a blast making your GIGABYTE your own. LED enthusiasts now have even more options with the ability to customize multiple zones independently. For a more functional use, the bright and vibrant LEDs can be configured to display the PC’s temperature or load. For even more LED goodness RGBW strips are now supported for more true and vibrant whites.
Multi-Zone Light Show Design
  • 16.8M RGB Colours.
  • 2 Programmable Sections.
  • 7 Different Lighting Effects .
  • 1 RGBW Light Strip Pin Header.
  • Accent LED with Interchangeable Overlay.
  • Advanced Mode for Extreme Customizability.
Lighting zone, programmable sections, wave mode may vary by model.
Lighting Effects:
  • Pulse.
  • Music.
  • Static.
  • Flash.
  • Colour Cycle.
  • Intelligent.
Supports RGBW & -UV Light Strips: Independently Programmable On-board Pin Header for RGBW/-UV LED Strips
Not bright enough? You can install standard 12V external RGB, RGBW or RGB/UV light strips on the RGBW pin header and control its colour from the RGB Fusion software. Using a RGBW light strip with a dedicated white LED, users will experience brighter and more vibrant shades of colours.
When using RGB/UV LED strips, users can give their systems a fluorescent glow with the use of UV reactive liquid, neon braided cables, and acrylic paint for a wicked-looking gaming PC.
No need to worry when choosing light strips as AORUS motherboards support a wide variety of RGBW/-UV light strips on the market thanks to the RGB Fusion software that allows users to redefine the pin location for the R/G/B Signal.
  • Fast USB 3.1 solution
    The USB 3.1 offers a staggering transfer speed, faster than USB 3.0 and backward compatibility with existing USB devices.
  • Faster and better coverage with 802.11ac Wi-Fi
    The onboard 802.11ac Wi-Fi module supports up to 867 Mb/s wireless networks and Bluetooth 4.2.
  • Fast onboard storage
    Gigabyte M.2 solution offers considerably faster storage performance and support for both PCIe and SATA interface for M.2 SSD devices.
  • Ambient LED
    Gigabyte motherboards feature LED lighting for the audio guard light path, providing a cool, custom look to your rig. These lights are programmable, so you can have them beat to the rhythm of the music you are listening to, or pulse at a soothing pace to create a great atmosphere to enhance the environment of your game, movie or music.
  • High-quality onboard audio design
    It delivers high-quality sound resolution and sound expansion to create the realistic sound effects for professional users.
  • DualBIOS design
    Gigabyte motherboards feature DualBIOS, an amazing technology from Gigabyte that protects arguably one of your PC's most crucial components, the BIOS. Gigabyte DualBIOS makes users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
Gigabyte GA-B250N Phoenix-WIFI - motherboard - mini ITX - LGA1151 Socket - B250
Motherboard - mini ITX
Chipset Type
Intel B250
Processor Socket
1 x LGA1151 Socket
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
Storage Ports
4 x SATA-600, 1 x M.2
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
LAN
Gigabit Ethernet
Chipset Type
Intel B250
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2400 MHz
Supported RAM Integrity Check
Non-ECC, ECC (operate in non-ECC mode)
Registered or Buffered
Unbuffered
Dual channel memory architecture, supported ECC modules operate in non-ECC mode
Audio
Audio Codec
Realtek ALC1220
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16
Storage Interfaces
SATA-600 -connectors: 4 x 7pin SATA, 1 x M.2
1 x HDMI , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 4 x USB 3.0 , 2 x USB 2.0 , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.0 - header
Hardware Features
3+2 Phase Power Design
