Smart Fan 5
With Smart Fan 5 users can ensure that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers that support both PWM and Voltage mode fans have been introduced to make the motherboard more liquid cooling friendly.
- 2 Fan pin headers.
- 4 Temperature Sensors.
- All Fan Pin Headers Upgraded to Hybrid Fan Headers.
- Supports High Current Fans up to 24W (2Ax12V) with Over-Current Protection.
- Intuitive UI for Fan Control.
All Hybrid Fan Pin Headers
- All Hybrid Fan Headers can automatically detect the type of cooling device whether it be fan or pump with different PWM or Voltage mode.
- Supports up to 2 amps with built-in overcurrent protection—a must for high-end high current fans.
Supports:
- Closed Loop Watercooling.
- CPU Fan.
- System Fan.
- Watercooling Pump.
New Smart Fan 5 Software
Choose from different modes, Quiet to Full Speed, to match your system usage scenario. For each fan or pump, you can use the intuitive fan curve to define trigger thresholds and corresponding fan speeds.
- Gigabyte GA-B250M-DS3H - 1.0 - motherboard - micro ATX - LGA1151 Socket - B250
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel B250
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
- Storage Ports
- 6 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1 GB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel B250
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2400 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC (operate in non-ECC mode)
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), supported ECC modules operate in non-ECC mode
Graphics
- 1 GB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
- 1 x VGA , 1 x HDMI , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard / mouse , 4 x USB 3.1 Gen 1 , 2 x USB 2.0
- Internal Interfaces
- 4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x parallel - header , 1 x SPDIF out - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
- Hardware Features
- Q-Flash, AutoGreen, Intel Extreme Memory Profile (XMP) support, On/Off Charge, 3TB+ Unlock, Audio Noise Guard with Path Lighting, Clear CMOS Button, GIGABYTE Ambient LED, Game Boost, Anti-Sulfur Design, Intel Optane Memory Ready, GIGABYTE Smart Fan 5
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE Smart Fan 5, GIGABYTE 3D OSD
- Plug and Play
- 22.6 cm
- 19.3 cm
