Gigabyte GA-AB350-Gaming 3 AMD B350 AM4 DDR4 M.2 USB3.1 ATX
Quicklinx: CR03WS00 Mfr#: GA-AB350-Gaming 3
Gigabyte GA-AB350-GAMING 3
  • Supports New Generation AMD Ryzen™ Processors
  • Dual Channel Non-ECC Unbuffered DDR4, 4 DIMMs
  • Fast 2 USB 3.1 Gen 2 with USB Type-A
  • Ultra Durable™ Metal Shielding over PCIe Slots
  • Ultra-Fast M.2 with PCIe Gen3 x4 & SATA interface
  • ALC 1220 120dB SNR HD Audio with Smart Headphone Amp
  • Realtek® Gigabit LAN with cFosSpeed Internet Accelerator Software
  • RGB FUSION with Multi-Zone LED Light Show design
  • Swappable Overlay for Accent LED
  • Smart Fan 5 features 6 Temperature Sensors and 5 Hybrid Fan Headers
  • GIGABYTE UEFI DualBIOS™
  • APP Center Including EasyTune™ and Cloud Station™ Utilities
  • Surround lighting
    Now offering more LED customizations than ever, users can truly adapt their PC to represent their lifestyle. With full RGB support, the user has complete control over the LEDs, which surround the motherboard.
  • Swappable overlay for accent LED
    Gigabyte brings even more color and life to your system with an accent LED overlay. This overlay complements the RGB Fusion technology in Gigabyte motherboards, adding more flare and style to your gaming machine. With the swappable overlay users can utilize different patterns and designs to make their system their own.
  • Smart Fan 5
    With Smart Fan 5 users can ensure, that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers, that support both PWM and Voltage mode fans, have been introduced to make the motherboard more liquid-cooling-friendly.
  • Enhanced BIOS interface
    The enhanced BIOS interface also has the advanced features seen in the Smart Fan 5 UI, such as: the ability to set triggers, based on different temperature sensors on the board, fan curve definition and the temperature interval setting, which can prevent fan rotation noise, caused by sudden temperature change.
  • Smart headphone amp
    Automatically detects impedance of your head-worn audio device, whether earbuds or high-end headphones, to provide optimal audio dynamics - preventing issues such as low volume and distortion.
  • Advanced audio capacitors
    Gigabyte gaming motherboards use Chemicon audio capacitors. These high-quality capacitors help deliver high-resolution and high-fidelity audio to provide the realistic sound effects for gamers.
  • USB DAC-UP 2 adjustable-voltage USB port with dedicated power design
    USB DAC-UP 2 continues to provide clean, isolated and low-noise power, while adding the ability to compensate for voltage drop. Virtual reality pioneers and gamers alike can rest assured, that their expensive accessories and peripherals will not encounter connectivity or power deficiency issues with the Gigabyte USB DAC-UP 2. With gaming gear, drawing large amounts of power and having firm specification requirements, USB DAC-UP 2 is up for the challenge.
  • Diagnostic LEDs
    Onboard LEDs, controlled by the system BIOS, indicate if a malfunction is occurring, allowing users to quickly diagnose, which major component is malfunctioning, so they may take action promptly.
  • Anti-sulfur resistor design
    Sulfur compounds in the air can penetrate tiny onboard resistors, creating chemical change and causing these resistors to open or short. If either of these occurs, the motherboard will fail to function. By equipping resistors with an anti-sulfur design Gigabyte gives ultra-durable motherboards another meaning.
Gigabyte GA-AB350-Gaming 3 - 1.0 - motherboard - ATX - Socket AM4 - AMD B350 FCH
Motherboard - ATX
Chipset Type
AMD B350 FCH
Processor Socket
1 x Socket AM4
Compatible Processors
Ryzen
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4 unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB 3.1 Gen 2 2 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 1 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD B350 FCH
Processor Socket
Socket AM4
Max Processors Qty
1
Ryzen
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2667 MHz, 2933 MHz (O.C.), 3200 MHz (O.C.)
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
2 GB
Audio
Audio Codec
Realtek ALC1220
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode (x2 mode if PCI Express 2.0 x1 slots is occupied)) , 1 x PCIe 2.0 x16 (x1 mode)
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 Gen 2 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 1 x DVI-D , 1 x HDMI , 4 x USB 3.1 Gen 1 , 1 x USB 2.0 , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
Diagnostic LEDs, Q-Flash, AutoGreen, On/Off Charge, Ultra Durable, Game Boost, RGB Ambient Surround LED, GIGABYTE Double Locking Bracket, Anti-Sulfur Design, G-Connector, GIGABYTE USB DAC-UP 2, GIGABYTE Smart Fan 5, RGB FUSION, Ultra Durable PCIe Armor, RGBW/-UV LED strips support
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE 3D OSD
Plug and Play
30.5 cm
23 cm
