GA-970A-DS3P FX
- Supports AMD AM3+ FX / AM3 series Processors
- GIGABYTE Ultra Durable™ Technology
- Audio Noise Guard with High Quality Audio Capacitors
- GIGABYTE UEFI DualBIOS™
- 2-way CrossFire™ Support
- 4 USB 3.1 Gen1 ports with transfer rates of up to 5Gbps
- GIGABYTE On/Off Charge™ for USB devices
High-quality onboard audio design
Delivers high-quality sound resolution and sound expansion to create realistic sound effects for professional gamers. -
Fast USB 3.1 Gen1 solution
With superfast transfer rates, users are able to experience an improvement. Additionally, backwards compatibility with USB 2.0 assures users legacy USB 2.0 devices will still work. -
Humidity protection Glass Fabric PCB
There is nothing more harmful to the longevity of your PC than moisture, and most parts of the world experience moisture in the air as humidity at some point during the year. GIGABYTE motherboards have been designed to make sure that humidity is never an issue, incorporating the Glass Fabric PCB technology that repels moisture caused by humid and damp conditions. Glass Fabric PCB technology uses a PCB material which reduces the amount of space between the fiber weave, making it much more difficult for moisture to penetrate compared to traditional motherboard PCBs. This offers much better protection from short circuit and system malfunction caused by humid and damp conditions. -
High ESD Ethernet & USB port protection
GIGABYTE motherboards raise the bar in terms of protecting your system, providing advanced electrostatic discharge (ESD) protection for both your Ethernet LAN and USB ports, both common sources of ESD-related failures. With pairing the dedicated protection filters, the Ethernet LAN and USB ports can withstand high electrostatic discharges, protecting your system from common electrical surges and even direct lighting strikes. -
GIGABYTE DualBIOS design
GIGABYTE Ultra Durable motherboards feature GIGABYTE DualBIOS, an exclusive technology that protects arguably one of your PC's most crucial components, the BIOS. GIGABYTE DualBIOS means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', protecting users from BIOS failure due to virus, hardware malfunction, improper OC settings or power failure during the update process.
- Gigabyte GA-970A-DS3P FX - 2.1 - motherboard - ATX - Socket AM3+ - AMD 990FX
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD 990FX / AMD SB950
- Processor Socket
- 1 x Socket AM3+
- Compatible Processors
- Athlon II, Phenom II, FX
- Data Bus Transfer Rate
- 5.2 GT/s
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3
- Storage Ports
- 6 x SATA-600 (RAID)
- USB / FireWire Ports
- 2 x USB 3.1 Gen 1 + 6 x USB 2.0 + (2 x USB 3.1 Gen 1 + 6 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- 5.2 GT/s
- Processor Socket
- Socket AM3+
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2000 MHz (O.C.)
- Dual channel memory architecture
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 (x4 mode) , 3 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- AMD SB950: SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD
- 1 x PS/2 keyboard , 6 x USB 2.0 , 2 x USB 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse
- Internal Interfaces
- 1 x audio - header , 1 x SPDIF out - header , 6 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, power supply fan tachometer
- Hardware Features
- Q-Flash, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, Audio Noise Guard with Path Lighting, GIGABYTE Smart Switch, GIGABYTE Double Locking Bracket
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Game Controller
- Plug and Play
- 30.5 cm
- 21.4 cm
Gigabyte GA-970A-DS3P FX AMD AM3+ DDR3 USB3.1 ATX
