Setting the high standard for all-around entertainment by providing a beautiful balance of gaming, entertainment, and work capabilities. Welcome to your go-to.
The G7 gaming laptop combines gaming, entertainment, work and more! Its powerful 11th Gen Intel Core i7 processer allows you to effortlessly handle multiple tasks at the same time.
Moreover, it features a 144Hz screen, 6TB storage capacity and next-gen Wi-Fi 6 technology; with a tool for every task, this laptop can be by your side as you weave through different roles, supporting more than fight and also your everyday life.
Windows 10 Home
11th Gen Intel® Core™ i7-i 7-11800H (2.2GHz~5.0GHz) - 8 Core NVIDIA® GeForce RTX™ 3050Ti
17.3"" Thin Bezel FHD 240Hz display
1+3 Multi Display for Multi-Tasking*
Support 3 Slots of Storage System Nahimic 3 3D Audio for Gamers
15 Full Area Colored Backlit Keyboard"
Experience the power of 11. The G5 gaming laptop comes equipped with the industry leading 11th Gen Intel® Core™ i7-i 7-11800H (2.2GHz~5.0GHz) - 8 Core processor. Users can stream, record gameplay, and run multiple applications without compromise. The G5 offers fast multimedia processing and the smoothest gaming experience.
The G7 gaming laptop is powered by Ampere: NVIDIA’s 2nd gen RTX architecture, NVIDIA® GeForce RTX™ 30 Series Laptop GPUs supports real-time ray tracing, artificial intelligence, and programmable shading, bringing gamers a whole new gaming/ working experience
Deep Learning Super Sampling (DLSS) uses deep learning and AI to train the GPU, rendering crisp images, while running 2x faster than previous generation GPUs that runs conventional anti-aliasing techniques.
Ray Tracing - Accurately reproduce realistic light ray and physics in game, producing a natural visual landscape for a next gen experience
Multitask like a Boss. 1+3 Display Multi-tasking Power
With DP, Mini DP and HDMI connectors, the G7 supports 3 external displays, making it a 1+3 display monster. This is the only station you need for work and all your entertainment media consumption
Store MONSTER File Size Games Support 3 Slots of Storage System -
The G7 gaming laptop comes with two M.2 slots and one 2.5 inch swappable bay, 3 slots offering a total of up to 6TB of storage space. Not to mention the 2 high-speed PCIe 3.0 x4 SSD slot’s unbelievable read speed of up to 3000 MB/s³, such storage performance is ready to take on beasty games with large sized files and all the other large media files with pure ease.
Seeing more special effect details
The G7 gaming laptop is powered by Ampere: NVIDIA's 2nd gen RTX architecture, NVIDIA GeForce RTX 30 series laptop GPUs support real-time ray tracing, artificial intelligence, and programmable shading, bringing gamers a whole new gaming/ working experience. -
Ray tracing
Ray tracing is the holy grail of gaming graphics, simulating the physical behavior of light to bring real-time, cinematic-quality rendering to even the most visually intense games. -
DLSS AI acceleration
NVIDIA DLSS is groundbreaking AI rendering that boosts frame rates with uncompromised image quality using the dedicated AI processing Tensor Cores on GeForce RTX. This gives you the performance headroom to crank up settings and resolutions for an incredible visual experience. The AI revolution has arrived to gaming. -
Dynamic Boost 2.0
The AI-powered Dynamic Boost 2.0 automatically delivers the needed power between the GPU, GPU memory, and CPU for a larger performance boost than ever before. The AI networks in Dynamic Boost 2.0 manage power on a per-frame basis, so your laptop is constantly optimizing for maximum performance while you're gaming and creating. -
Resizable BAR
Resizable BAR is an advanced PCI Express feature that enables the CPU to access the entire GPU frame buffer at once, improving performance in many games. -
True-to-life 144Hz display
G7 comes equipped with 144Hz gaming display that brings out the true gaming colors. The 144Hz high refresh rate display takes away motion blur and only leaves a perfectly smooth image experience. A clear glance of the enemy is the key to victory! -
Wi-Fi 6 technology without lag
The Wi-Fi 6 technology that comes with dual band, dual channel feature. Plus Bluetooth 5.2, G7 provides blazing speed performance whether indoors or outdoors. -
Light and thin design
The G7 gaming laptop chassis is coated with a discrete matte black finish, designed with function in mind and optimally packed to achieve a weight of just 5.25lbs. The G7 packs such power, yet it is so portable. -
DTS:X Ultra: Immerse yourself in cinema-grade sound
The G7 series adapts the DTS:X Ultra audio technology for the first time and letting you enjoy the full depth of high-fidelity audio. Virtual 7.1-channel surround sound innovation that provides outstanding sound experience and performance. From gaming, seeing movies to conference calls, the DTS:X Ultra brings true 3D surround effect and the voice communication is clearer than ever with Two-Way AI Noise Cancelation that removes noise from incoming and outgoing audio.
- Gigabyte G7 MD 71UK123SH - 17.3" - Intel Core i7 - 11800H - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i7 (11th Gen) - 11800H / 2.3 GHz, up to 4.6 GHz / 24 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD @ 240 Hz
- Graphics
- NVIDIA GeForce RTX 3050 Ti / Intel UHD Graphics
- Video Memory
- 4 GB GDDR6 SDRAM
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.2, Gigabit Ethernet
- Battery
- Up to 4 hours
- Security
- Firmware Trusted Platform Module (TPM) Security Chip
- 39.5 cm x 26.2 cm x 3.23 cm
- 2.38 kg
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Intel Core i7 (11th Gen) 11800H / 2.3 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 8-core
- Cache
- 24 MB
- Chipset
- Mobile Intel HM570 Express
- Intel Smart Cache, Intel Platform Trust Technology (PTT)
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 240 Hz
- Widescreen
- Image Aspect Ratio
- 16:9
- Colour Gamut
- 72% NTSC
- Anti-glare, thin bezel design, IPS-level
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR6 SDRAM
- Video System Features
- NVIDIA Optimus, Max-Q design, NVIDIA Resizable BAR, Dynamic Boost 2.0
- Camera
- Yes - HD
- Sound
- Stereo speakers, dual array microphone
- DTS:X Ultra
- Audio Features
- Output: Nahimic 3 sound technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- 15 colours backlighting
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 200
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8411B
- Capacity
- 48.96 Wh
- Run Time
- Up to 4 hours
AC Adapter
- Output
- 150 Watt
Connections & Expansion
- Slots
- 1 x M.2 (PCI Express 3.0) , 1 x M.2 (PCI Express 4.0)
- Interfaces Details
- LAN , USB-C 3.2 Gen 2 , Mini DisplayPort 1.4 , USB 3.2 Gen 1 , USB 3.2 Gen 2 , USB 2.0 , Microphone input , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card)
- Security
- WINDFORCE Cooling System
- Included Accessories
- Power adapter
- 2.38 kg
Sustainability Information
- TCO Certified
