Gigabyte G5 KC-5UK1130SH with Aorus H1 headset bundle
Quicklinx: GPKTWS00 Mfr#: G5 KC-5UK1130SH
  • Core i5
  • IEEE 802.11n
GIGABYTE G5 Gaming Laptop:For Both Work & Play. Weave through Different Roles Effortlessly
Setting the new standard for all-around entertainment by providing a beautiful balance of gaming, entertainment, and work capabilities. Welcome to your new go-to.
The G5 gaming laptop combines gaming, entertainment, work and more! Its powerful 10th Gen Intel® Core™ i5 processor allows you to effortlessly handle multiple tasks at the same time.
Moreover, it features up to a 144Hz screen, 3 screen display output, built-in SD card slot, 6TB storage capacity and next-gen Wi-Fi 6 technology; with a tool for every task, this laptop can be by your side as you weave through different roles, supporting you more in the fight and also your everyday life.
Simultaneous Multitasking Made Easy.
Experience the power of 10. The G5 gaming laptop comes equipped with the 6 core industry leading Intel® 10th Gen Core™ i5 - 10500H processor. Users can run multiple applications without compromise. The G5 offers fast multimedia processing and the smoothest gaming experience.
Seeing More Special Effect Details
GeForce RTX™ 30 Series Laptop GPUs
The G5 gaming laptop is powered by Ampere: NVIDIA’s 2nd gen RTX architecture, NVIDIA® GeForce RTX™ 30 Series Laptop GPUs supports real-time ray tracing, artificial intelligence, and programmable shading, bringing gamers a whole new gaming/ working experience.
Ray Tracing
Accurately reproduce realistic light ray and physics in game, producing a natural visual landscape for a next gen experience
DLSS
Deep Learning Super Sampling (DLSS) uses deep learning and AI to train the GPU, rendering crisp images, while running 2x faster than previous generation GPUs that runs conventional anti-aliasing techniques.
Zero in with Crystal Clear Aim.
True-to-Life 144Hz Display
The G5 gaming laptop comes equipped with 144Hz gaming display which covers 72 % NTSC colour gamut that can bring out more vivid gaming colours. The 144Hz high refresh rate can take away motion blur and leave a perfectly smooth visual experience. Clear sight is the key to victory!
Multitask like a Boss.
1+3 Display Multi-tasking Power
With DP, Mini DP and HDMI connectors, the G5 supports 3 external displays, making it a 1+3 display monster. This is the only station you need for work and all your entertainment media consumption.
Dual Gigantic Fans
Two 5V fans with 47-fan blades and 53-fan blades that continuously pump out internal hot air.
4 Heatpipes
The internal chassis consists of 4 total heat-pipes, with 2 of these heat-pipes dedicated to dissipating the heat generated from the CPU and GPU.
3 Vents
3 exhausts vents and intakes coming from the large under area of the chassis, effectively cooling the chassis with proper airflow.
Store MONSTER File Size Games
Support 3 Slots of Storage System
The G5 gaming laptop comes with two M.2 slots and one 2.5 inch swappable bay, 3 slots offering a total of up to 6TB of storage space. Not to mention the 2 high-speed PCIe 3.0 x4 SSD slot’s unbelievable read speed of up to 3000 MB/s³, such storage performance is ready to take on beasty games with large sized files and all the other large media files with pure ease.
Tune Your Performance.
GAMING CENTER
Using the all-new GAMING CENTER, gamers can easily set the game performance, macro keys and backlit key effects . Create custom profiles for each game to maximise your true potential.
Modern Detailing
Light and Thin Design
Extremely Thin Bezel
G5 gaming laptop with a thin-bezel display design, pushing the boundary of technology by having a 15.6 inch display in a portable 14 inch like chassis. The G5 breaks the gaming laptop tradition by offering portability where others can’t.
The G5 gaming laptop chassis is coated with a discrete matte black finish, designed with function in mind and optimally packed to achieve a weight of just 4.85 lbs. The G5 packs such power, yet it is so portable.
Dance with Your Fingertips
15 Preset LED Settings
The G5 gaming laptop keyboard comes with 15 preset backlit effects, giving you the ability to customize the lighting effects to express your personal style.
NAHIMIC 3 Surround Sound Tech | The Shattering Experience
NAHIMIC 3 is the next gen 7.1 virtual surround sound innovation that provides outstanding sound experience and performance. From gaming to conference calls, the NAHIMIC 3 brings true 3D surround effect that can be tuned easily with the provided software to suit any environment for the perfect sound experience.
Surround Sound
Feel the immersion, feel the sound as if you were in the heart of the action.
Device Compatibility
Jack, USB, Bluetooth, HDMI. Nahimic is compatible with all of your audio tools.
Sound Tracker
The Sound Tracker is a visual indicator that points out the directions from which predominant sounds are coming.
  • True-to-life display
    The G5 gaming laptop comes equipped with a superior gaming display that can bring out more vivid gaming colors. The high refresh rate can take away motion blur and leave a perfectly smooth visual experience. Clear sight is the key to victory!
  • Multitasking power
    With DP, Mini DP and HDMI connectors, G5 supports three external displays, making it a 1+3 display monster. This is the only station you need for work and all your entertainment media consumption.
  • Stay cool and win
    The G5 gaming laptop is equipped with the WINDFORCE Cooling System. Not only does it help G5 achieve superior CPU and GPU outputs but also remains quite and stable at the same time.
  • Wi-Fi 6 technology without lag
    The G5 gaming laptop comes with Intel Wireless-AX200, supporting Wi-Fi 6. Plus with Bluetooth 5.0, G5 provides blazing speed performance whether indoors or outdoors.
  • Nahimic 3 surround sound tech
    Nahimic 3 provides outstanding sound experience and performance. From gaming to conference calls, Nahimic 3 brings true 3D surround effect that can be tuned easily with the provided software to suit any environment for the perfect sound experience.
Opperating System
Windows 10 Home
CPU
10th Gen Intel Core i5-10500G (2.5GHz~4.5GHz)
Display
15.6" Thin BEzel 244Hz FHD 1920x1080 IPS-Level Anti Glare Display LCD
System Memory
2x 8GB DDR4 3200MHz (Max 64GB)
Chipset
Mobiel intel HM470 Express Chipset
Video Graphics
Intel UHD Graphics 630, NVIDIA GeForce RTX 3060 Laptop GPU GDDR 6GB
Storage
1x 512 PCIe m.2 SSD installed
Keyboard
15 Full Area Colour RGB Backlit Keyboard
I/O
1x USB 2.0 Type A, 1x USB 3.2 Gen 1 Type A, 1x USB 3.2 Gen Type A, 1x HDMI 2.0, 1x mini DP 1.4, 1x Display port 1.4 Type C over USB 3.2 Gen 2, 1x Audio combo jack, 1x Microphone Jack, 1x SD Card Reader, 1x DC - in jack, 1x RJ45
Audio
2x 2 Watt Speaker, Dual Array Microphone, NAHIMIC 3
Communications
LAN: RTL8411B EALTEK 2.5G Ethernet, Wlan : Intel AX200 Wireless, Bluetooth V5.0 + LE
Webcam
HD Camera
Security
Fireware based TPM
Adapter
180W
Li Polumer 48.96Wh
Dimensions
361 (W)x 258 (D)x 27.9(H) mm
2.2kg
