As an unseen player, monitor is often being underestimated. The truth is monitors form as a synergistic effect and bring out the best performance of PC components. Gigabyte gaming monitors offer the ultimate specifications and quality, users can truly enjoy upscale performance without the need for extravagance.
31.5" 1500R VA panel presents you a view closer to the human eye than a flat monitor, giving you a more immersive feel.
High resolution and fast refresh rate, giving you the detailed display quality and fluid gaming experience!
The last mile for your gaming system
As an unseen player, monitor is often being underestimated. The truth is monitors form as a synergistic effect and bring out the best performance of PC components. Gigabyte gaming monitors offer the ultimate specifications and quality, users can truly enjoy upscale performance without the need for extravagance. -
Your super immersive feel in the game
31.5" 1500R VA panel presents you a view closer to the human eye than a flat monitor, giving you a more immersive feel. -
QHD with 165Hz
High resolution and fast refresh rate, giving you the detailed display quality and fluid gaming experience! -
8-bit color, 94% DCI-P3
Fantastic color display and 94% DCI-P3 super wide-gamut color. -
Simple but stylish
The streamline appearance represents the simplicity of the Gigabyte gaming series design philosophy, sturdy stand and matte finish built for functional and aesthetic features adding more to the characteristics. -
OSD Sidekick
Gigabyte OSD Sidekick allows you to set the display options with keyboard and mouse, giving you the easiest way to adjust monitor settings. -
Auto-update
Users can effortlessly enjoy the finest gaming experience with features Gigabyte continues to develop and upgrade while giving extra protection to your monitor. -
Perfect viewing angle
Gigabyte gaming monitor features an exclusive stand that's ergonomically designed to offer extensive range of height and tilt adjustments.
- Gigabyte G32QC - LED monitor - curved - 31.5" - HDR
- LED-backlit LCD monitor - 31.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/397781
- Energy Class
- Class G
- Power Consumption (On mode)
- 39 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync Premium Pro
- USB 3.0 hub
- Panel Type
- VA
- Native Resolution
- QHD 2560 x 1440 at 165 Hz
- Pixel Pitch
- 0.2724 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- HDR Capable
- DisplayHDR 400
- Response Time
- 1 ms (MPRT)
- Colour Gamut
- 124% sRGB, 94% DCI-P3
- Input Connectors
- 2xHDMI, DisplayPort
- Height, tilt
- Screen Coating
- Anti-glare
- 71.05 cm x 23.48 cm x 55.22 cm
- 7.8 kg
- DisplayPort 1.2
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Diagonal Size
- 31.5"
- Curved Screen
- Yes (1500R)
- Built-in Devices
- USB 3.0 hub
- Panel Type
- VA
- Native Resolution
- Pixel Pitch
- 0.2724 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- HDR Certification
- DisplayHDR 400
- Colour Gamut
- Response Time
- 1 ms (MPRT)
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- Edge-lit LED
- Flicker Free technology, Low Blue Light technology, AORUS Aim Stabilizer
- 7.8 kg
- 2 x HDMI , DisplayPort , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream , Microphone , Headphones
Mechanical
- Height, tilt
- Tilt Angle
- -5/+20
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- HDMI cable , DisplayPort cable , USB cable
- DisplayPort 1.2
- Security Slot Type
- Kensington security slot
- 39 W
- Power Consumption SDR (On mode)
- 39 kWh/1000h
- Power Consumption HDR (On mode)
- 62 kWh/1000h
- Power Consumption (Typical)
- 75 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 71.05 cm - depth: 23.48 cm - height: 55.22 cm - weight: 7.8 kg , Without stand - width: 71.05 cm - depth: 10.28 cm - height: 42.33 cm
- Shipping Width
- 86 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 55.5 cm
- Shipping Weight
- 10.8 kg
