Gigabyte G27Q Monitor
Quicklinx: GQY6WS00 Mfr#: G27Q
As an unseen player, monitor is often being underestimated. The truth is monitors form as a synergistic effect and bring out the best performance of PC components. GIGABYTE gaming monitors offer the ultimate specifications and quality, users can truly enjoy upscale performance without the need for extravagance.
Performance
Superfast 1ms response time for the most smooth gaming experiance
QHD and 144Hz for High resolution and fast refresh rate, giving you the detailed display quality and fluid gaming
Fantastic color display and 92% DCI-P3 super wide-gamut color.
Characteristic
The streamline appearance represents the simplicity of the GIGABYTE gaming series design philosophy, sturdy stand and matte finish built for functional and aesthetic features adding more to the characteristics
Gaming Features
GIGABYTE OSD Sidekick allows you to set the display options with keyboard and mouse, giving you the easiest way to adjust monitor settings
The dashboard reveals your real-time hardware information including CPU voltages, clock speeds, temperatures, etc. The best part is that it wont be blocked by any games.
Black Equalizer allows you to have more detailes of the dark areas without over exposing the bright side at the same time.
Users can effortlessly enjoy the finest gaming experience with features Gigabyte continues to develop and upgrade while giving extra protection to your monitor
Tech Features
Flicker Free - Preventing eye strain and fatigue
Clear Sound - offering the quality sound experience
Low Blue Light - Certified for eye health protection
Perfect Viewing Angle
Feature an exclusive stand that's ergonomically designed to offer extensive range of height and tilt adjustments
Height adjustment : 130mm
Tiit angle : -5 to +20 Degrees
  • Dashboard
    The dashboard reveals your real-time hardware information including CPU voltages, clock speed, temperatures, etc. The best part is that it won't be blocked by any games.
  • Black Equalizer
    This feature allows you to have more details of the dark side without overexposing the bright side at the same time.
  • Auto-Update
    Users can effortlessly enjoy the finest gaming experience with features GIGABYTE continues to develop and upgrade while giving extra protection to your monitor.
  • Simple but stylish
    The streamline appearance represents the simplicity of the GIGABYTE gaming series design philosophy, sturdy stand and matte finish built for functional and aesthetic features adding more to the characteristics.
  • Alignment
    The display alignment function will facilitate you on the multi-display set-up, monitors will line up perfectly.
  • Perfect viewing angle
    GIGABYTE Gaming monitor features an exclusive stand that's ergonomically designed to offer extensive range of height and tilt adjustments.
Gigabyte G27Q - LED monitor - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/393820
Energy Class
Class G
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
28 W
USB 3.0 hub
Panel Type
IPS
Native Resolution
QHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.2331 mm
Brightness
320 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
HDR Capable
DisplayHDR 400
Response Time
1 ms (MPRT)
Colour Gamut
120% sRGB, 92% DCI-P3
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
61.904 cm x 20.297 cm x 51.888 cm
6.7 kg
DisplayPort 1.2
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
50 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
320 cd/m²
Contrast Ratio
HDR Certification
DisplayHDR 400
Colour Gamut
Response Time
1 ms (MPRT)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
Edge-lit LED
Flicker Free technology
61.904 cm x 20.297 cm x 51.888 cm - with stand
6.7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , DisplayPort , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable
DisplayPort 1.2
Security Slot Type
Kensington security slot
28 W
28 kWh/1000h
Power Consumption HDR (On mode)
44 kWh/1000h
Power Consumption (Typical)
65 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 61.904 cm - depth: 5.6 cm - height: 36.5526 cm , With stand - width: 61.904 cm - depth: 20.297 cm - height: 51.888 cm - weight: 6.7 kg
Shipping Width
73.7 cm
Shipping Depth
49.5 cm
Shipping Height
21.8 cm
Shipping Weight
9.7 kg
