Gigabyte Force M9 Ice Wireless Laser Mouse
Quicklinx: 85WTWS00 Mfr#: GM-FORCE M9ICE
Performance Wireless Laser Mouse
Works On Virtually Every Surface, Including Ice and Glass!
The cutting-edge GIGABYTE ICE Technology™ is a kind of laser tracking system which makes FORCE M9 ICE work on almost every surface, giving you extra freedom of motion. Not only can it work on the desk or sofa, it also performs great on crystal clear surface, like glass and ice!
4-Stage DPI Adjustable
Easily flick the button and adjust DPI at your fingertip with intuitive LED indicator on the mouse. 800 / 1200 / 1600 / 2000 DPI adjustable
GIGABYTE Free-Scrolling Technology
GIGABYTE Free-Scrolling Technology™ facilitates webpage browsing and boosts efficiency
Personalize Your Mouse with GIGABYTE SIM Software
You may download GIGABYTE SIM software from the official website, and then change button functions to suit your needs with simple clicks. Personalizing mouse button function is like mouse make-over. It helps to boost work efficiency, and make your mouse one-of-the-kind!
Modern Design
Ergonomic shape with modern design
GIGABYTE ICE Technology™ - works on almost every surface, including glass and ice
4-Stage DPI adjustable - 800/1200/1600/2000 DPI
Personalize your mouse with GIGABYTE SIM™ software
Outstanding design
  • GIGABYTE ICE technology
    The cutting-edge GIGABYTE ICE technology is a kind of laser tracking system which makes FORCE M9 ICE work on almost every surface, giving you extra freedom of motion. Not only can it work on the desk or sofa, it also performs great on crystal clear surface, like glass and ice!
  • 4-stage dpi adjustable
    Easily flick the button and adjust dpi at your fingertip with intuitive LED indicator on the mouse, 800/1200/1600/2000 dpi adjustable.
  • GIGABYTE Free-Scrolling technology
    GIGABYTE Free-Scrolling technology facilitates webpage browsing and boosts efficiency.
  • Modern design
    It's ergonomic shape with modern design.
Gigabyte GM-FORCE M9 ICE - mouse - icy black
Mouse
Wireless
Icy black
7.3 cm x 12.6 cm x 4.3 cm
100 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Movement Resolution
2000 dpi
Performance
3200 fps
Lighting dpi switch, GIGABYTE Free-Scrolling Technology, GIGABYTE ICE Technology
2 x AA type
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Mouse
Wireless Receiver
7.3 cm
12.6 cm
4.3 cm
100 g
Icy black
Input Device
Wireless
Laser
Movement Resolution
2000 dpi
Performance
3200 fps
1 x USB 2.0 - 4 pin USB Type A
FCC
AA type
Installed Qty
2
