Gigabyte FI32U
Gigabyte FI32U
Quicklinx: GQYFWS00 Mfr#: FI32U-EK
4K. Transforming Your Gaming Experience!
AORUS FI32U, 31.5-inch UHD resolution and equipped with the latest HDMI® 2.1, 144Hz refresh rate and 1ms GTG for the most fluid gaming experience and awesome picture quality. The 10-bit color and super-wide color gamut of 90% DCI-P3/ 123% sRGB offering the outstanding color accuracy and consistency. It's DisplayHDR400™ certified to ensure spectacular display quality, ultimate gaming and entertainment experience.
SS IPS - Splendid color with furious speed
UHD 4K - 3,840 x 2,160 pixels
HDMI2.1 - VRR and ALLM
90% DCI-P3
10 bits color 8 bits + FRC
Audiophile sound - Sound by Audio ESS SABRE HiFi
The 4K Experience
With more higher resolution game content have been created in order to have the best visual experience, it is time for you to invest a 4K display! AORUS 4K Monitors delivers crisp, detailed visual and offers you a more true-to-life viewing experience!
SS IPS with 1ms GTG
Super Speed IPS panel provides splendid color meanwhile the crystals reduce the response time to reach 1ms GTG
31.5" with 4K
31.5" UHD panel (3840 x 2160 resolution) in a 16:9 aspect ratio with a 144Hz refresh rate for fluid gameplays.
HDMI 2.1
The newest HDMI 2.1 can improve your gaming experience by providing a higher bandwidth of 4K@144Hz, offering a competitive advantage on a range of games from adventure to shooters. The new standard also supports the next-gen consoles
10-bit with 90% DCI P3
AORUS FI32U is a 10-bit display (8-bit + FRC) with 90% of DCI-P3 color space, offering the richer variety of color graduations and greater accuracy
VESA DisplayHDR 400
High Dynamic Range (HDR) expands the range of light of a display, what's better is that you can enjoy the exclusive HDR modes we offer to level up your gaming and entertainment experience!
Audiophile sound
AORUS adopts the concept of a high-end audiophile sound system design into a micro system on the monitor. The embedded ESS SABRE chip provides a pure yet powerful sound, resonating classical orchestral sounds or blasts in your virtual warzone. Enjoy the depth of the music and the immersive sound profile.
OSD SIDEKICK
The exclusive AORUS OSD Sidekick allows you to quickly set the display options with keyboard and mouse. It's even better now you can enjoy the up-to-date gaming experience through the latest exclusive Auto-Update function!
ANC FOR CONSOLE
AORUS monitors provide up to 120dB Signal-to-Noise ratio playback quality, and support up to 600 ohm headphones. The latest upgrade is that gamers get to choose premium audio with or without headsets on!
AIM STABILIZER SYNC
Upgraded Aim Stabilizer is able to conduct the motion blur reduction and V-Sync technology at the same time! Greatly improving your FPS aim!
BLACK EQUALIZER
The Black Equalizer deepens the details of the dark side on the scene without affecting other display areas. Enabling this feature to reveal all of your hidden enemis!
DASHBOARD
The Dashboard shows you critical hardware information in real-time. No matter what kinds of scenario, it won't be blocked by any game. It's even customizable that you get to choose to show the info that matters to you most!
6 AXIS COLOR CONTROL
This feature allows you to adjust six colors (red, green, blue, cyan, magenta, and yellow) individually to more accurately display the color gamut on the monitor
KVM
KVM feature allows you to control multiple devices via one set of keyboard, video and mouse
DESIGN CONCEPT
In the AORUS dimension, everything is constructed digitally. The lighting and patterns are mapped onto the products with an efficient, free flowing style. Welcome to the Digital Code Era.
ERGONOMIC DESIGN
AORUS Gaming monitor features an exclusive stand that's ergonomically designed to offer extensive range of height, tilt, pivot, and swivel adjustments
Swivel: -20 to +2- degrees
Pivot: +90 Degrees
Height Adjustment:130mm
Tilt: -5 to +21 Degrees
Eyesafe - Certified to meet the standard for colour balance and blue light reduction
Flicker Free - Without causing eye strain and other injuries
USB Charger - superspeed USB Charger provides 5V/ 1.5A power
Power Board Built in - no additional bulky power adaptor needed
  • The 4K experience
    With more higher resolution game content have been created, in order to have the best visual experience, it is time for you to invest a 4K display! AORUS 4K monitors delivers crisp, detailed visual and offers you a more true-to-life viewing experience!
  • HDMI 2.1
    The HDMI 2.1 can improve your gaming experience by providing a higher bandwidth of 4K@120Hz, offering a competitive advantage on a range of games from adventure to shooters. The new standard also supports the next-gen consoles.
  • Audiophile sound
Gigabyte AORUS FI32U - LED monitor - 4K - 31.5" - HDR
LED-backlit LCD monitor - 31.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/427545
Energy Class
Class G
USB 3.0 hub
Panel Type
SS IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 144 Hz
Pixel Pitch
0.181 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
HDR Capable
DisplayHDR 400
Response Time
1 ms (grey-to-grey), 1 ms (MPRT)
Colour Gamut
123% sRGB, 90% DCI-P3
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
71.76 cm x 23.8 cm x 59.83 cm
10.9 kg
DisplayPort 1.4
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
SS IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.181 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
HDR Certification
DisplayHDR 400
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
Edge-lit LED
Picture by picture, Black eQualizer, Flicker Free technology, Picture-in-Picture, AORUS Aim Stabilizer, Gigabyte RGB Fusion 2.0, High Bit Rate 3 (HBR3), ANC 2.0, AORUS Dashboard, AORUS OSD Sidekick, 10-bit(8-bit + FRC) Colour Depth
71.76 cm x 23.8 cm x 59.83 cm - with stand
10.9 kg
2 x HDMI , DisplayPort , USB-C , Headphones , Microphone , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
40
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x USB-C cable
DisplayPort 1.4
Security Slot Type
Kensington security slot
Input Voltage
40 kWh/1000h
Power Consumption HDR (On mode)
51 kWh/1000h
Power Consumption (Typical)
120 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 71.76 cm - depth: 23.8 cm - height: 59.83 cm - weight: 10.9 kg , Without stand - width: 71.76 cm - depth: 7.13 cm - height: 42.43 cm - weight: 7.7 kg
Shipping Width
1 m
Shipping Depth
19.8 cm
Shipping Height
58.5 cm
Shipping Weight
15.4 kg
