GIGABYTE engineers have developed an ultra compact PC with a stylish design based around an anthracite aluminum frame and glass surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough (56mm x 107mm x 114mm) to sit in the palm of your hand.
Redefining the desktop PC
GIGABYTE engineers have developed an ultra compact PC with a stylish design based around an anthracite aluminum frame and glass surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough (56mm x 107mm x 114mm) to sit in the palm of your hand. -
Intel Celeron N2807
Based on the Silvermot micro-architecture, utilizing the 22nm process technology. The SoCs feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage. -
Advanced features for power users
The Brix is engineered to take full advantage of what the hardware and its UEFI BIOS are capable of. And therefore, it's designed to deliver the most intuitive and integrated operating systems in the world. -
Trouble-free setup
The BRIX is packed with wall mount adapter whether undergo rigorous testing for safety and reliability. The BRIX also bundled with a VESA bracket, it can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This offers a simple and elegant way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
- Gigabyte BRIX GB-BXBT-2807 (rev. 1.0) - Ultra Compact PC Kit Celeron N2807 1.58 GHz - 0 GB - no HDD
- PC barebone - Ultra Compact PC Kit - UEFI BIOS
- Processor
- 1 x Intel Celeron N2807 / 1.58 GHz (up to 2.16 GHz, (Dual-Core)
- Processor Main Features
- Intel Burst Technology
- Cache Memory
- 1 MB
- Cache Per Processor
- 1 MB
- RAM
- 0 GB (installed) / 8 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics - up to
- Audio Output
- Integrated
- Networking
- 1GbE, 802.11b/g/n, Bluetooth 4.0
- Power
- AC 120/230 V
- OS Provided
- No operating system
- 10.76 cm x 11.44 cm x 5.61 cm
- PC barebone
- Product Form Factor
Processor / Chipset
- CPU
- Intel Celeron N2807
- Clock Speed
- 1.58 GHz
- Max Turbo Speed
- 2.16 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 1 MB
- 1 MB
RAM
- Installed Size
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 1 (Total) / 1 (empty)
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- VGA, HDMI
- Max Monitors Supported
- 2
Audio Output
- Integrated
- Ethernet Controller
- Realtek RTL8111G
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Half Mini Card
- 1 x USB 3.0 (1 in front) , 1 x HDMI , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x audio line-out/microphone - mini-jack
- Included Accessories
- VESA wallmount adapter
- UEFI BIOS
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Power adapter
- Voltage Required
- AC 120/230 V
Operating System / Software
- OS Provided
- 10.76 cm
- 11.44 cm
- 5.61 cm
Gigabyte Brix GB-BXBT-2807 Ultra Compact Mini-PC Celeron N2807
