Gigabyte Brix GB-BXBT-2807 Ultra Compact Mini-PC Celeron N2807
Quicklinx: 9MH0WS00 Mfr#: GB-BXBT-2807
  • Bluetooth 4.0
  • IEEE 802.11n
  • Celeron
GIGABYTE engineers have developed an ultra compact PC with a stylish design based around an anthracite aluminum frame and glass surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough (56mm x 107mm x 114mm) to sit in the palm of your hand.
  • Redefining the desktop PC
  • Intel Celeron N2807
    Based on the Silvermot micro-architecture, utilizing the 22nm process technology. The SoCs feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage.
  • Advanced features for power users
    The Brix is engineered to take full advantage of what the hardware and its UEFI BIOS are capable of. And therefore, it's designed to deliver the most intuitive and integrated operating systems in the world.
  • Trouble-free setup
    The BRIX is packed with wall mount adapter whether undergo rigorous testing for safety and reliability. The BRIX also bundled with a VESA bracket, it can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This offers a simple and elegant way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
Gigabyte BRIX GB-BXBT-2807 (rev. 1.0) - Ultra Compact PC Kit Celeron N2807 1.58 GHz - 0 GB - no HDD
PC barebone - Ultra Compact PC Kit - UEFI BIOS
1 x Intel Celeron N2807 / 1.58 GHz (up to 2.16 GHz, (Dual-Core)
Processor Main Features
Intel Burst Technology
Cache Memory
1 MB
Cache Per Processor
1 MB
RAM
0 GB (installed) / 8 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics - up to
Audio Output
Integrated
1GbE, 802.11b/g/n, Bluetooth 4.0
AC 120/230 V
OS Provided
No operating system
10.76 cm x 11.44 cm x 5.61 cm
PC barebone
Product Form Factor
Processor / Chipset
CPU
Intel Celeron N2807
Clock Speed
1.58 GHz
Max Turbo Speed
2.16 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
1 MB
Cache Per Processor
1 MB
RAM
Installed Size
DDR3L SDRAM
SO-DIMM 204-pin
Slots
1 (Total) / 1 (empty)
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Intel HD Graphics
Video Interfaces
VGA, HDMI
Max Monitors Supported
2
Audio Output
Integrated
Ethernet Controller
Realtek RTL8111G
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Half Mini Card
1 x USB 3.0 (1 in front) , 1 x HDMI , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x audio line-out/microphone - mini-jack
VESA wallmount adapter
UEFI BIOS
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
AC 120/230 V
Operating System / Software
OS Provided
No operating system
10.76 cm
11.44 cm
5.61 cm
