Challenging the essence of how they define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. With a broad choice of processors covering the entire performance spectrum, the BRIX sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
Intel HD Graphics deliver 10% more performance than its predecessor. With the new media engine users are able to, watch, create, edit, share and game all with captivating visuals. This media engine offers HEVC 10-bit hardware acceleration which improves upon the 4K viewing and content creation performance significantly versus previous generation processors. The BRIX now has the ability to drive premium content up to 4K UHD, so users can enjoy amazing and vibrant multimedia experiences on compatible displays.
BRIX supports up to three independent displays through HDMI and a DisplayPort ++ without the need for an additional graphics card. Support for three display is only possible with daisy-chain connections through Display Port++.
The perfect fit for any space
Challenging the essence of how they define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. With a broad choice of processors covering the entire performance spectrum, the BRIX sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. -
Graphics that Captivate
Intel HD Graphics deliver 10% more performance than its predecessor. With the new media engine users are able to, watch, create, edit, share and game all with captivating visuals. This media engine offers HEVC 10-bit hardware acceleration which improves upon the 4K viewing and content creation performance significantly versus previous generation processors. The BRIX now has the ability to drive premium content up to 4K UHD, so users can enjoy amazing and vibrant multimedia experiences on compatible displays. -
Fast USB 3.1 Solution
The USB 3.1 offers a staggering 10 Gb/s transfer speed, 2x faster than USB 3.0 and backward compatibility with existing USB devices. -
Multi-display productivity with HDMI & DisplayPort++
BRIX supports up to three independent displays through HDMI and a DisplayPort ++ without the need for an additional graphics card. Support for three display is only possible with daisy-chain connections through Display Port++. -
VESA support
Bundled with a VESA bracket, the GIGABYTE BRIX can easily be mounted behind a monitor or HDTV, offering a simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
- Gigabyte BRIX GB-BKi3A-7100 (rev. 1.0) - Ultra Compact PC Kit - Core i3 7100U 2.4 GHz - 0 GB - no HDD
- PC barebone - Ultra Compact PC Kit
- Processor
- 1 x Intel Core i3 (7th Gen) 7100U / 2.4 GHz (Dual-Core)
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 620
- Audio Output
- Stereo
- Networking
- 1GbE
- Power
- AC 120/230 V
- OS Provided
- No operating system
- 11.26 cm x 11.94 cm x 3.44 cm
- PC barebone
- Product Form Factor
Processor / Chipset
- CPU
- Intel Core i3 (7th Gen) 7100U
- Clock Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 0 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Slots
- 1 M.2 Card - 2230 , 2 (total) / 2 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2280
- 2 x USB 3.0 , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone - mini-jack (1 in front) , 1 x USB 3.1 (1 in front) , 1 x USB-C 3.1 (1 in front)
- Included Accessories
- VESA wallmount adapter
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Power adapter
- Voltage Required
- AC 120/230 V
Operating System / Software
- OS Provided
- 11.26 cm
- 11.94 cm
- 3.44 cm
- 0 °C
- 35 °C
