Gigabyte BRIX Celeron 2955U 1.4GHz Ultra Compact PC Kit
Quicklinx: 999SWS00 Mfr#: GB-BXCE-2955
  • Bluetooth 3.0
  • Bluetooth 4.0
  • Celeron
  • IEEE 802.11n
The BRIX from Gigabyte is an ultra compact and versatile DIY PC kit. The BRIX redefines the desktop PC in terms of miniaturization with a form factor that sits in the palm of your hand. Ideal for compact HTPC builds or as a standard desktop in the home or office, the BRIX doesn't hold back in terms of display and peripheral connectivity, or raw performance.
  • Redefining the desktop PC
    Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. The BRIX sets a standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
  • Dual-display
    With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
  • VESA support
    The BRIX can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This makes it simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
Gigabyte BRIX GB-BXCE-2955 (rev. 1.0) - Ultra Compact PC Kit - Celeron 2955U 1.4 GHz - 0 GB - no HDD
PC barebone - Ultra Compact PC Kit
1 x Intel Celeron 2955U / 1.4 GHz (Dual-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
0 GB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics
Audio Output
Stereo - integrated
GigE, 802.11b/g/n, Bluetooth 3.0, Bluetooth 4.0
AC 120/230 V
OS Provided
No operating system
10.76 cm x 11.44 cm x 2.99 cm
PC barebone
Product Form Factor
Processor / Chipset
CPU
Intel Celeron 2955U
Clock Speed
1.4 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
0 GB / 16 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Intel HD Graphics
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Ethernet Controller
Realtek RTL8111G
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 3.0, Bluetooth 4.0
Slots
1 (total) / 1 (free) x mSATA , 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Half Mini Card
4 x USB 3.0 (2 front, 2 rear) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x SPDIF output/headphones (1 in front)
VESA wallmount adapter
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
AC 120/230 V
Operating System / Software
OS Provided
No operating system
10.76 cm
11.44 cm
2.99 cm
