Challenging the essence of how a desktop PC is defined, Gigabyte engineers have developed an ultra compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. The BRIX sets a different standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high-productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
Redefining the desktop PC
Challenging the essence of how a desktop PC is defined, Gigabyte engineers have developed an ultra compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. The BRIX sets a different standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. -
Dual display
With support for HDMI and Mini DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high-productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications. -
Extreme USB 3.1 controller
Gigabyte introduces the fast 10 Gb/s USB 3.1 Gen2 protocol to its BRIX units over the advanced reversible USB Type-C port. Additionally, USB 3.1 is backwards compatible with 3.0 making the Gigabyte BRIX a versatile and widely compatible small form factor PC. -
Reversible Dual USB Type-C with USB 3.1
The USB Type-C is an alternative reversible connector that is loaded with useful features such as USB 3.1 support for 10 Gb/s transfer speed. Powered by the USB 3.1 controller, this little port provides the amazing USB Type-C experience. -
VESA support
The BRIX can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This makes it simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
- Gigabyte BRIX GB-BSi7T-6500 (rev. 1.0) - Ultra Compact PC Kit - Core i7 6500U 2.5 GHz - 0 GB - no HDD
- PC barebone - Ultra Compact PC Kit
- Processor
- 1 x Intel Core i7 (6th Gen) 6500U / 2.5 GHz (, up to 3.1 GHz, (Dual-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 4 MB
- Cache Per Processor
- 4 MB
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- Intel HD Graphics 520
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- No operating system
- 11.26 cm x 11.94 cm x 3.44 cm
- PC barebone
- Product Form Factor
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6500U
- Clock Speed
- 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 4 MB
- 4 MB
RAM
- Installed Size
- 0 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Ethernet Controller
- Intel I219-V
- Data Link Protocol
- Slots
- 2 M.2 Card , 2 (total) / 2 (free) x SO-DIMM 260-pin
- 4 x USB 3.0 (2 in front) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack (1 in front) , 1 x microphone - mini-jack (1 in front) , 1 x USB-C 3.1
- Included Accessories
- VESA wallmount adapter
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Power adapter
- Voltage Required
- AC 120/230 V
Operating System / Software
- OS Provided
- 11.26 cm
- 11.94 cm
- 3.44 cm
- 0 °C
- 35 °C
