Gigabyte B85N-PHOENIX S1150 Intel B85 DDR3 mITX
Quicklinx: 9Y97WS00 Mfr#: GA-B85N-PHOENIX
GIGABYTE Ultra Durable 4 classic motherboards embrace a range of exclusive features that guarantee DIY PC builders the absolute best protection for their PC, with built-in features that prevent common malfunction threats users encounter on a day-to-day basis.
GIGABYTE Ultra Durable 4 classic motherboards feature high resistance ICs which help protect the motherboard against electrostatic discharge.
  • UEFI DualBIOS technology
    With a superior graphical interface capable of 32-bit color imaging and fluid user-friendly mouse navigation, UEFI DualBIOS makes BIOS configuration an exciting experience for novice and experienced users alike. UEFI BIOS also brings native support for large hard drives on 64-bit operating systems.
  • GIGABYTE Ultra Durable 4 classic
  • Humidity protection
    Humidity can play havoc on a motherboard's circuitry. GIGABYTE's glass fabric PCB design helps protect against electrical shorts due to humidity by reducing the gaps in spacing between PCB filaments.
  • Electrostatic protection
  • Power failure protection
    Permanent damage from power surge or failure during BIOS update can be avoided with GIGABYTE DualBIOS which automatically enables secondary, backup BIOS. GIGABYTE also uses anti-surge ICs to protect the motherboard against power surges.
  • High temperature protection
    GIGABYTE uses all solid caps and low RDS (on) MOSFETs which are rated to work at higher temperatures, providing extended component lifespan.
  • All solid capacitors
    GIGABYTE Ultra Durable motherboards are equipped with solid capacitors which provide the stability, reliability and longevity essential to meet the power needs of high-end processors and other components running today's most demanding applications and games.
  • On/Off Charge technology
    GIGABYTE On/Off Charge technology allows you to charge your iPhone, iPad and iPod Touch regardless of whether your PC is on, in standby mode or even off. A derivative of GIGABYTE's highly acclaimed 3x USB Power feature, On/Off Charge enables devices to draw more current from GIGABYTE motherboard USB ports than standard USB ports allow, so that charging from your PC can be as fast as with a charger.
  • HDMI-the next generation multimedia interface
    HDMI is a High-Definition Multimedia Interface which provides up to 5 Gbps video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI is compatible with HDCP (High-bandwidth Digital Content Protection), allowing the playback of Blu-ray/HD DVD and other protected media content.
  • ErP Lot 6 support
    The ErP (also known as Energy-Related Products Directive) is part of the European Union's environmental regulations policy. It is based on concern for the environmental as the proliferation of electronic devices continues, and how to improve energy efficiency for a better and greener life. GIGABYTE supports ErP and produces motherboards that help you effectively improve system efficiency.
Gigabyte GA-B85N Phoenix - 1.1 - motherboard - mini ITX - LGA1150 Socket - B85
Motherboard - mini ITX
Chipset Type
Intel B85 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC
Storage Ports
4 x SATA-600, 1 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 5 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel B85 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC898
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
2 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16 , 1 x Mini PCIe , 1 x CPU
Storage Interfaces
SATA-600 -connectors: 3 x 7pin SATA, 1 x mSATA - 4 devices , SATA-300 -connectors: 1 x 7pin Serial ATA - 1 devices
1 x HDMI , 1 x DVI-I , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 5 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack
Internal Interfaces
2 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x SPDIF out - header , 1 x audio - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage
Hardware Features
DualBIOS, Q-Flash, Onboard LED, Intel Extreme Memory Profile (XMP) support, On/Off Charge, One Port One Fuse, GIGABYTE 333 Onboard Acceleration, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel Small Business Advantage support, ESD Protection, Ultra Durable 4 Plus, Clear CMOS Button, GIGABYTE USB DAC-UP
Software Included
Drivers & Utilities, Norton Internet Security, @BIOS, EasyTune, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock
Plug and Play, ACPI 5.0
17 cm
17 cm
