Gigabyte 7 series motherboard takes advantage of the connectivity and expansion bus technologies on the Intel platform. The 3rd generation Intel Core processor platform debuts the PCI Express generation 3.0 expansion bus, allowing users to take advantage of the next generation, high-bandwidth discrete graphics card solutions.
Gigabyte 7 series motherboard features an onboard mSATA slot allowing users to easily take advantage of advanced SSD-based technologies like Intel Smart Response and Intel Rapid Start. Mounting an affordable, low capacity mSATA SSD directly onto your motherboard can enhance your PC's performance with better overall desktop responsiveness, faster boot times and faster system resume from 'suspend to disk' and 'standby' modes.
Designed for PCI Express generation 3 support
Gigabyte 7 series motherboard takes advantage of the connectivity and expansion bus technologies on the Intel platform. The 3rd generation Intel Core processor platform debuts the PCI Express generation 3.0 expansion bus, allowing users to take advantage of the next generation, high-bandwidth discrete graphics card solutions. -
Intel Rapid Start Technology
With Intel Rapid Start Technology the previous session resumes to the exact as it was, so that applications are still in the same state and no application data is lost. -
Intel Smart Connect technology
Intel Smart Connect technology means that your email, favorite apps, and social networks are continually and automatically updated even when the system is asleep. No more waiting for the latest world news or friends' updates to be delivered - just press the 'on' button and you're up-to-date and ready to go. -
Onboard mSATA support
Gigabyte 7 series motherboard features an onboard mSATA slot allowing users to easily take advantage of advanced SSD-based technologies like Intel Smart Response and Intel Rapid Start. Mounting an affordable, low capacity mSATA SSD directly onto your motherboard can enhance your PC's performance with better overall desktop responsiveness, faster boot times and faster system resume from 'suspend to disk' and 'standby' modes. -
UEFI DualBIOS technology
With a superior graphical interface capable of 32-bit color imaging and fluid user-friendly mouse navigation, UEFI DualBIOS makes BIOS configuration a new and exciting experience for novice and experienced users alike. UEFI BIOS also brings native support for large hard drives on 64-bit operating systems. -
50,000 hours Japanese solid capacitors
Gigabyte ultra durable motherboard is equipped with solid capacitors developed by leading Japanese manufacturers. With an average lifespan of 50,000 hours, these solid capacitors provide the stability, reliability and longevity essential to meet the power needs of high-end processors and other components running today's most demanding applications and games... -
SuperSpeed USB 3.0
Gigabyte motherboard boasts SuperSpeed USB 3.0 technology made possible through an additional onboard host controller. With superfast transfer rates of up to 5 Gbps, users are able to experience a theoretical 10x improvement over USB 2.0. Additionally, backwards compatibility with USB 2.0 assures users of long term use of their legacy USB 2.0 devices. -
SATA 6 Gbps
Gigabyte motherboard is high-speed SATA revision 3.0 compatible, delivering superfast 6 Gbps link speeds for twice the data transfer rates of SATA revision 2.0 (3 Gbps). When used in RAID 0 (stripe) mode, it offers even faster data transfer rates of up to a theoretical 4x the speed of current SATA interfaces. -
3x USB power boost
Gigabyte motherboard features a 3x USB power boost, delivering greater compatibility and extra power for USB devices. Gigabyte's unique USB power design is also able to efficiently regulate output over the full voltage range, which greatly enhances USB device compatibility. In addition, dedicated lower resistance fuses ensure lower voltage drops, and provide more stable and plentiful power delivery. -
LAN Optimizer - intelligent optimization network management tool
Gigabyte LAN Optimizer is designed to allow the user to manage different types of network traffic so that data streams such as HD media, web browsing or online gaming can be prioritized, taking precedence over large data downloads that tend to strangle overall network bandwidth. -
On/Off Charge technology
Gigabyte On/Off Charge technology allows you to charge your iPhone, iPad and iPod Touch regardless of whether your PC is on, in standby mode or even off. A derivative of Gigabyte's highly acclaimed 3x USB power feature, On/Off Charge enables devices to draw more current from Gigabyte motherboard USB ports than standard USB ports allow, so that charging from your PC can be as fast as with a charger... -
Multi-display support with AMD CrossFireX
AMD CrossFireX delivers the ultimate graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution. -
DVI support
DVI (Digital Visual Interface) is a video interface standard designed for carrying uncompressed digital video data and to maximize the visual quality of digital display devices, such as LCD monitors, digital projectors, and so on. In addition, the DVI interface is compatible with HDCP (High-bandwidth Digital Content Protection).
- Gigabyte GA-B75-D3V - 1.0 - motherboard - ATX - LGA1155 Socket - B75
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel B75 Express
- Processor Socket
- 1 x LGA1155 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC
- Storage Ports
- 1 x SATA-600, 5 x SATA-300
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel B75 Express
- Processor Socket
- LGA1155 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Speed
- PC3-12800, PC3-10600, PC3-8500
- Supported RAM Integrity Check
- Non-ECC
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- SATA-600 -connectors: 1 x 7pin Serial ATA - 1 devices , SATA-300 -connectors: 4 x 7pin SATA, 1 x mSATA - 5 devices
- 1 x PS/2 keyboard / mouse , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 1 x SPDIF out , 1 x audio , 4 x USB 2.0 , 2 x USB 3.0 , 1 x serial
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
- Hardware Features
- DualBIOS, Q-Flash, AutoGreen, 3x USB Power Boost, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Ultra Durable 4 Classic, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, GIGABYTE LAN Optimizer
- Software Included
- @BIOS, Xpress Recovery 2, Q-Share
- Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
- 30.5 cm
- 21.5 cm
Gigabyte B75-D3V S1155 Intel B75 DDR3 ATX
